need help on diode selection
·I have a circuit where there is a coil energized switch drawing 6 amps at 12 volts.·There is also a 5 watt light wired·from the·switch to ground for visual confirmation when switch is turned on.
·Question;·I will need·a diode for reverse voltage spike when switch is turned off·but how many amps above the 6 should I use.
allie
allie
I think you quoted the (irrelevant) current through the relay contacts rather than through the relay coil anyway.· There are relays that require a coil current of six amperes, but that's a mighty big relay.· Mighty big.
· -- Carl, nn5i@arrl.net
This depends on how many turn on's/off's your switch is doing. Is this a manual switch, or are you switching a transistor or something at a high frequency?
Carl you are right about, it is a big current but it is the coil current.
·I don't have any 1n400x series diodes but I do have some 1n914 switching diodes,will these work also.
allie
Almost any diode that is intended for service as a power rectifier will serve you, but a small-signal diode like a 1n914 would be a very poor choice.· When it fails, it will probably fail open.· Then you lose its protection, and you burn up whatever was trying to shut off the coil current.
Post Edited (Carl Hayes) : 4/3/2009 3:27:58 PM GMT
I found 1 1n4001 diode which I'll use. But I have another circuit which draws 3 amps and I desoldered a 1n4002 which I'll use. As I understand the 1 stands for 1 amp and the 2 stands for 2 amps and 3,4,---so on.
·So the 1n4002 should do the job.
allie
Mike2545
This message sent to you on 100% recycled electrons.
If you must put diodes in parallel. place a small resister in series with each diode.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
They will explode because one of them (the one with the least forward drop) will conduct all the current meant for several, and it will overheat.· After that one explodes, the one with the next lowest drop will conduct all the current until it explodes.· And so forth.
Sometimes they don't explode but only burn out, if the total current is small enough.· In that case you can omit the armor plate.
Post Edited (Carl Hayes) : 4/4/2009 8:22:42 PM GMT
