PING sensor as tank level sensor
The mechanical fluid-level sensor on my home heating oil tank has broken. Would the Parallax PING sensor work as a way of sensing the level of oil remaining in the tank? It seems it should bounce off the surface of the oil in the tank pretty much as well as anything else. The tank is pretty still so I don't expect it to be so disturb as to not work. But what about echos returning from the sides of the tank?
Any reason I should be concerned about ultrasonic waves and 275 gallons of diesel fuel?
Peter
Peter
Dave
Dave Andreae
Parallax Tech Support
Post Edited (Dave Andreae (Parallax)) : 4/3/2009 3:24:45 PM GMT
Thanks for the link. This is pretty much exactly what I want to do. Now I just have to find the parts which were all given to me last year when I attended the Prop Expo in Ohio.
If I can find that stuff and get this built, I'll let you know how it goes.
p
Mike2545
This message sent to you on 100% recycled electrons.
This was a great get together of prop users orgaznized by Jeff Ledger (aka OldBitCollector) last August in Norwalk, OH. You can find more info about this year's event at:
http://www.warrantyvoid.us/upene/
http://forums.parallax.com/showthread.php?p=785269
pgb
Mike2545
http://warrantyvoid.us/tiki-index.php
and
http://forums.parallax.com/forums/default.aspx?f=25&m=328817
I'm happy to report that this works just as you suggested it would. Honestly, I wasn't too pre-cautious with my test, but diesel (and fumes) aren't explosive unless under pressure. None the less, now that I know this can work, I'll put together a proper case for the PING to keep any possible sparks away from the tank. Now I need to come up with a way of turning a distance to the surface of the oil into gallons remain. Time to dig out my calc book.
Peter
Searider
I am designing a circuit for a tank as well my problem is that the sensor has to be no more than 5 inches alway from the top of the tank and the tank is 5 inches deep, the bisgest problem that I am facing is the acuracy that has to be around 1/4 inches , could anybody help me please
thanks
I think the PING sensor should be able to "see" things as close as 3cm. I'm not sure about the accuracy. Maybe you can find something in the documentation on the parallax website:
www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/ProductID/92/List/0/Default.aspx?SortField=ProductName,ProductName
If I can find all the parts again, I can test it for you. How critical is the 1/4"?
p
