Pololu motor contoller with basic stamp 2 question...
Hello all,
I am trying to get the Pololu motor controller to work with two motors and the basic stamp 2 but it doesn't seem to work!
I have it all setup like the doc says but nothing.
I am trying different buad rates but am not sure what number is used for the set buad rate.· I know 84 means 9600 but what are the other buad rates?
I can use 9600 to 19200 but don't know the number for 19200.
also, did anyone else get this thing to work, and if so can you show me your code because the one I am using out of the doc doesn't work.
That or both of my controller are dead, which doesn't seem likely.
thanks
Joe
“Intellectual growth should commence at birth and cease only at death”
Albert Einstein
thanks
Joe
Albert Einstein
I got mine to work well. I don't think I ever used two motors, however. Unfortunately, I can't do any testing for you because I no longer have it.
My GUESS is that you nailed it when you mentioned not knowing how to set the baud rate.
--Bill
You are what you write.
I've only used one motor with it, but here's the code I used. Hope it helps.
' Playing with the Polou Dual DC motor controller ' ' {$STAMP BS2p} ' {$PBASIC 2.5} ' ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- _MotorSDA PIN 1 _MotorRST PIN 0 ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Baud CON 84 ' 9600,N,8,1 'Baud CON 240 ' 9600,N,8,1 for BS2p ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- idx VAR Byte idx2 VAR Byte ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Main: HIGH _MotorSDA LOW _MotorRST PAUSE 5 HIGH _MotorRST PAUSE 100 ' Configure Polou Dual Motor controller for single motor ' mode, motor number = 0. SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $02, $40] LOW _MotorRST PAUSE 5 HIGH _MotorRST PAUSE 100 Loop1: ' Spin forward DEBUG "Ramping forward...",CR FOR idx = 32 TO 127 SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $00, $01, idx] PAUSE 20 NEXT DEBUG "Full forward...",CR PAUSE 3000 SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $00, $01, $0] PAUSE 500 DEBUG "Full backward...",CR SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $00, $00, $7F] PAUSE 3000 DEBUG "Ramping down...",CR ' Spin backward FOR idx = 127 TO 32 SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $00, $00, idx] PAUSE 20 NEXT DEBUG "Stop.",CR SEROUT _MotorSDA, Baud, [noparse][[/noparse]$80, $00, $00, $0] PAUSE 2000 GOTO loop1
