hb25 motor in fwd and reverse
how does one make the motor go in reverse?. i can only get fwd. any ideas? thanks
' File...... HB-25 Motor Test.bs2
' Purpose... Tests One Or Two HB-25's Connected To P15
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' Updated... 01-18-2006
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program tests the HB-25 by waiting for it to power up, then pulsing
' the output to ramp the motors up in opposite directions, wait 3 seconds
' then ramp them back down to a stopped position. While the code is
' written for two HB-25/motors you can use it with just one by commenting
' out or removing the lines for the second motor, commented below. If you
' have two HB-25/motors connected, remember to remove the jumper block from
' the second HB-25.
[noparse][[/noparse] I/O Definitions ]
HB25 PIN 15 ' I/O Pin For HB-25
[noparse][[/noparse] Variables ]
index VAR Word ' Counter For Ramping
[noparse][[/noparse] Initialization ]
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 5 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor 1
PAUSE 1 ' 1 mS Delay
PULSOUT HB25, 750 ' Stop Motor 2 (If Connected)
' The Above 2 Lines May Be Removed
' If You Are Using Single Mode
[noparse][[/noparse] Program Code ]
Main:
PAUSE 20 ' Wait 20 mS Before Ramping
FOR index = 0 TO 250 ' Ramp Up To Full Speed
PULSOUT HB25, 750 + index ' Motor 1 Forward
PAUSE 1 ' 1 mS Delay For Motor 2 Pulse
PULSOUT HB25, 750 - index ' Motor 2 Reverse
PAUSE 20 ' 20 mS Smoothing Delay
NEXT
PAUSE 3000 ' Wait 3 Seconds
FOR index = 250 TO 0 ' Ramp Back Down
PULSOUT HB25, 750 + index ' Motor 1 Forward Slowing
PULSOUT HB25, 750 - index ' Motor 2 Reverse Slowing
NEXT
STOP
' {$STAMP BS2}
' {$PBASIC 2.5}
' the second HB-25.
Main:
NEXT
NEXT
STOP
The test program should turn the motor(s) one way, pause for 3 seconds, and then turn the motor(s) in the other direction. Depending on the pulse you provide the HB-25 will determine how the motor will rotate.
In the future, please use the attachment manager for sample code; as that makes it easier to load into the BASIC Stamp Editor. Thank you
Joshua Donelson
www.parallax.com
make sure its a - after the 750 -
- Stephen
What is the power source for your HB25, and what is the current demand of your motors? I have seen what you describe if the HB25 was inadequately powered.
Beau Schwabe
IC Layout Engineer
What do you mean by "inadequately powered"? Are you refering to the power to the motors "posts" or the power to the pins?
I am having problems with inconsistancy whereas the same code produces different results.
I have read the documentation and can't figure out how to troubleshoot this.
"Everything is working so why do we pay him?"
"Nothing is working so why do we pay him?"
I had a long wire running from a BS2p40 pin to the HB-25 control pin. It worked fine. Eventually, I changed robot brains (five Stamps for one SX48) and hooked everything back up. The HB-25 did not respond. I remembered reading about bypass capacitors. So, I stuck one between each HB25 control line, I have two·HB-25s·on my machine·(the wire from the SX48 to the HB-25 control pin), and ground.
All problems disappeared.
Now, I am dedicated to using bypass capacitors. Many folks say it is good practice. Here is a nice, short article on their use.
--Bill
You are what you write.
What I meant was... The HB25 is designed to handle a decent amount of current. Don't feed it something like a 9V battery and expect it to perform, it needs more oomph than that.
Beau Schwabe
IC Layout Engineer
I thought it could handle 6-16Volts? I am using the Parallax 7.2v power plug and connecting the input side of the HB25 to VIN. Is that not enough.
I did notice that the HB25 worked better at higher speed.
"I thought it could handle 6-16Volts?" - It can, I'm talking current here... if your current is not adequate then the HB25 might have a difficult time doing what you tell it to do.
Beau Schwabe
IC Layout Engineer
Obviously I don't have a lot of experience with this so could you tell me what the voltage and current should be to make tis work?
I have attached a schematic of my setup.
The voltage applied to the HB25(s) is 6-12V at 2Amps
The motors I am driving are small hobby motors.
Tamiya FA-130
Voltage: 1.5-3V (1.5V Recommended) (4.5 V max)<!--mstheme--><!--msthemelist-->
RPM: 6990-9100 (6990 Max. Efficiency)
Amperage: .66A
Nice schematic.
Do you have the HB-25s set up in "Mode 1?" (Page 2.) That is the mode necessary for one HB-25 to control one motor. The jumper "J", must be in place. See the data.pdf, as I'm sure you have a thousand times, by now.
I use a lot of HB-25s. I cannot say I know a lot about them because they are so easy to use. You might disconnect one of the HB-25/motor sets and work with a single set until you get everything ironed out. Cut the test code down so that it just runs a single HB-25. Forget about ramping (for now). Use something like this: PULSOUT HB25, 870 after the HB-25 is "ready."
On the off-chance that one of your HB-25s is bad, try the other one.
I run mine off a 12 volt, lead-acid battery. I have never tried anything else.
When you get the bug(s) out of your setup, you will like these motor controllers.
--Bill
Thanks, I have the jumper on both and am currently trying to use them seperately. I have tried what you said about disconnecting them and only using one then the other with very simple code but I still can't predict the behavior.
Chris Savage
Parallax Engineering
