3 Steppers 1 BS2 Question??
First off I would like to say hello 2 everyone. I am just getting involved into microcontrollers and have built and coded a few Model train systems Assesory Decoders , Pir EBrake system and so on. Now i built a mini cnc machine and have used the parallax demo step code as a base . I do not plan on writing codes for g or any other stuff just bs2 straight to steppers. I am using 3 uln's 1 for each stepper and have set everything up based off of parallax's experiment 26 or whatever. I had no problem with 1 or even running dual. Note each motor will only run 1 at a time so I don't think I have power issues but who knows. Each stepper has its own voltage regulator and I am not using my stamps power at all....Excecpt to the array's....Now this code listed here is just a complete copy for more motors. Coils1 (OUTB) is the original and (OUTC) & (OUTD) I have added.....Here's where I get confused when you run this code it runs the first 2 perfect but when it gets to OUTD Im only getting power at· pin12 which is the first pin in OUTD...So why no power out of pin13,14,15.... To answer a couple questions I now I'm going to get asked....When I change the outputs to A,B,C it does the same thing even though I'm not using OUTD it will be like OUTC doesn't get anything on the last 3 pins in its group. I have verified that the wiring to steppers and stamp are correct and have run all 3 of these motors in different Dual setups but just can't tackle 3 for some reason. I am using LEDS to show me my steps on the board and can furnish a video of the code running. But I know once someone reads this you'll knoow what the problem is. I think I just don't know enough about writing code...I am making leaps and bounds every week though...Thanks for the help In advance.........Radridz3
P.S. this mini cnc is probably only going to make 1 certain pcb for me so once the codes done where goooooood....Im just going to use it to drill boards because im starting to look like popeye on 1 arm from holding the Dewalt for a thousand holes..>>..>.>>>>>.....
' {$STAMP BS2} ' {$PBASIC 2.5} ' ------------------------------------------------------------------------------ ' I/O Definitions ' ------------------------------------------------------------------------------ Coils1 VAR OUTB Coils2 VAR OUTC Coils3 VAR OUTD ' ------------------------------------------------------------------------------ ' Constants ' ------------------------------------------------------------------------------ Scale1 CON $100 Unknown1 CON 5 StpsPerRev1 CON Unknown1 Scale2 CON $100 Unknown2 CON 25 StpsPerRev2 CON Unknown2 Scale3 CON $100 Unknown3 CON 50 StpsPerRev3 CON Unknown3 Scale4 CON $100 Unknown4 CON 100 StpsPerRev4 CON Unknown4 Scale5 CON $100 Unknown5 CON 200 StpsPerRev5 CON Unknown5 ' ------------------------------------------------------------------------------ ' Variables ' ------------------------------------------------------------------------------ speed VAR Word idx VAR Byte stpIdx VAR Byte ' ------------------------------------------------------------------------------ ' EEPROM Data ' ------------------------------------------------------------------------------ Step1 DATA %1100 Step2 DATA %0110 Step3 DATA %0011 Step4 DATA %1001 ' ------------------------------------------------------------------------------ ' Initialization ' ------------------------------------------------------------------------------ Setup: DIRB = %1111 speed = 1 DIRC = %1111 speed = 1 DIRD = $1111 speed = 1 ' ------------------------------------------------------------------------------ ' Program Code ' ------------------------------------------------------------------------------ Main: FOR idx = 1 TO StpsPerRev5 GOSUB Step_Fwd1 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev4 GOSUB Step_Rev1 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev3 GOSUB Step_Fwd1 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev2 GOSUB Step_Rev1 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev1 GOSUB Step_Fwd1 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev5 GOSUB Step_Fwd2 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev4 GOSUB Step_Rev2 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev3 GOSUB Step_Fwd2 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev2 GOSUB Step_Rev2 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev1 GOSUB Step_Fwd2 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev5 GOSUB Step_Fwd3 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev4 GOSUB Step_Rev3 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev3 GOSUB Step_Fwd3 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev2 GOSUB Step_Rev3 NEXT PAUSE 500 FOR idx = 1 TO StpsPerRev1 GOSUB Step_Fwd3 NEXT PAUSE 500 GOTO Main: ' ------------------------------------------------------------------------------ ' Subroutines ' ------------------------------------------------------------------------------ Step_Fwd1: stpIdx = stpIdx + 1 // 4 READ (Step1 + stpIdx), Coils1 PAUSE speed RETURN Step_Rev1: stpIdx = stpIdx + 3 // 4 READ (Step1 + stpIdx), Coils1 PAUSE speed RETURN Step_Fwd2: stpIdx = stpIdx + 1 // 4 READ (Step1 + stpIdx), Coils2 PAUSE speed RETURN Step_Rev2: stpIdx = stpIdx + 3 // 4 READ (Step1 + stpIdx), Coils2 PAUSE speed RETURN Step_Fwd3: stpIdx = stpIdx + 1 // 4 READ (Step1 + stpIdx), Coils3 PAUSE speed RETURN Step_Rev3: stpIdx = stpIdx + 3 // 4 READ (Step1 + stpIdx), Coils3 PAUSE speed RETURN
- Stephen
Find the typo and you win!
Setup:
· DIRB = %1111
· DEBUG BIN16 ? DIRS
· speed = 1
· DIRC = %1111
· speed = 1
· DIRD = $1111
· speed = 1
· STOP
