Longer(er) Distance Infrared Transmission
I've been working towards building a simple beacon to track object, and decided to use an infrared LED (here or here, I used them alternately) on the beacon and matching receiver (here) on the mobile module.
Well, I got to do some testing tonight, and it didn't go as well as I hoped. I used two different LEDs that were suitable (correct wavelength) with similar results. I could only get reliable data out to about three feet, then it started to fall apart until at about 16 feet nothing more was sensed. I think (big step here) that the problem is weak LEDs. I viewed the LED through my digital camera, and I could barely make it out at about 5 feet, so it's unlikely that the IR detector could see it from there either. Granted, I was running at about 60 ma (out of 100 ma max), but I had hoped for better results of 20 feet at least.
The circuit that I used was a Darlington array (at 5v) pulsed by the Propeller. The Led has two 20 ohm resistors in series.
I'll probably give these high power LEDs a shot since they should be about 5 times as powerful if I run them at full tilt (300 ma).
I also tried shielding the receiver with a long tube, but it didn't seem to help (trouble aiming and holding probably contributed some).
So, the other option is a laser. I was thinking about getting the appropriate laser with a lens to make the dot a bar, but I'm wary of that option due to the danger (no blink reflex for IR). But with high power LEDs is it any different? I don't know...
Any suggestions?
Post Edited (SRLM) : 3/31/2009 5:41:00 AM GMT
Any suggestions?
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ BS2 : "BS2_Functions" ' Create BS2 Object PUB Start BS2.start (31,30) ' Initialize BS2 Object timing, Rx and Tx pins for DEBUG repeat BS2.FREQOUT(23, 1000, 56000) 'Freqout one second at 56 kHz waitcnt(clkfreq + cnt) 'Wait one secondAnd the BS2 receiver program
' {$STAMP BS2} ' {$PBASIC 2.5} TX PIN 12 ' serial output to LCD T9600 CON 84 LcdBaud CON T9600 LcdCls CON $0C ' clear LCD (use PAUSE 5 after) LcdBLon CON $11 ' backlight on LcdOn1 CON $16 ' LCD on; cursor off, blink off LcdLine1 CON $80 ' move to line 1, column 0 LcdLine2 CON $94 ' move to line 2, column 0 hightime VAR Word lowtime VAR Word HIGH TX ' setup serial output pin DIR7 = 0 PAUSE 100 ' allow LCD to initialize 'Prepare LCD (clear it, backlight, turn off cursor) SEROUT TX, LcdBaud, [noparse][[/noparse]LcdCls] PAUSE 10 SEROUT TX, LcdBaud, [noparse][[/noparse]LcdBLon] SEROUT TX, LcdBaud, [noparse][[/noparse]LcdOn1] DO 'Find high time DO WHILE IN7 = 1 AND hightime < 1500 hightime = hightime + 1 LOOP 'Display high time SEROUT TX, LcdBaud, [noparse][[/noparse]LcdLine1,"H:", DEC5 hightime] hightime = 0 'Find low time DO WHILE IN7 = 0 AND lowtime < 1500 lowtime = lowtime + 1 LOOP 'Display low time SEROUT TX, LcdBaud, [noparse][[/noparse]LcdLine2,"L:", DEC5 lowtime] lowtime = 0 LOOPBasically, what my program does is to just 'toggle' the IR receiver alternately low and high. I know success by when the high and low times on my LCD match up, and failure when they are different. I've pulled out my Parallax oscilloscope and tested to make sure that I am indeed transmitting at 56kHz, and I am. One oddity that I noticed is that the oscilloscope software shows a peak to peak hight of <150 mV. It's odd, but I don't know what it means. I can't use a multimeter to check, since the meter is to slow (with the changes).
I just tried transmitting with the second led (LED55CF) that says its rated for 10A pulsed. When I tried (with about 500 mA) by removing my resistors, it got really hot. I'm afraid that my lack of practical circuit knowledge is showing through...
Post Edited (SRLM) : 3/31/2009 6:12:00 AM GMT
Post Edited (Phil Pilgrim (PhiPi)) : 3/31/2009 7:09:59 AM GMT
Addedum: The transistor I recommended has a fairly high gate capacitance (2.4nF). You may want to add a small series resistor between the Prop and the gate to limit the transient pin current. 75 ohms will help and will still gve you a sub-microsecond rise time.
Post Edited (Phil Pilgrim (PhiPi)) : 3/31/2009 3:56:20 PM GMT
Signature space for rent!
Send $1 to CannibalRobotics.com.
