ASM Help, Causes Full Prop Lockup, or Doesn't do anything
Hi all thanks for taking the time to read this and or help.
Simply I am trying to create a pulse based off the falling edge of an incoming pulse that occurs a variable amount of time from the incoming pulse and lasts for 2 milliseconds.
So my test program is a simple cog start then start the terminal with two buttons that allows me to change the delay value. I judge if the prop is working by terminal output, and if the program is effective with a two channel scope.
I am feeding the prop a pulse signal 50% high @ 120khz from a function generator.
Here is what I have
If I call my cognew with PulseDelayStart I get nothing, the terminal does not run at all, it appears the whole prop is locked up.
If I call the cognew with PulseStart the terminal runs and the value changes up and down, but the program does not work, which makes sense as the Outpin pin is not an output.
So any ideas suggestions?
Thank you TJ
I owe everyone here a bunch, So thanks again for answering my dumb questions.
Projects. RG500 ECU system. PropCopter. Prop CanSat. Prop Paste Gun.
Suzuki RG500 in a RGV 250 frame.
Bimota V-Due (Running on the fuel injection system)
Aprilia RS250
Here is what I have
Con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PinIn = 0
PinOut = 1
MS2 = (80_000_000/1_000) * 2 'A 2 Milisecond Delay
obj
Term : "serial_terminal"
Var
Long TimeDelay
Pub Run
TimeDelay := 1000 'Set a base value
cognew(PulseDelayStart, @TimeDelay) 'Start a new cog w/ the asm program
term.start 'Start the terminal
dira~ 'Set pin 2 to input
dira~ 'Set pin 3 to input
repeat
term.out(0) 'Clear terminal screen
term.dec(TimeDelay) 'Print current timeing delay value
if ina == 0 'if pin 2 is low, increase timeing value
TimeDelay++
elseif ina == 0 'if pin 3 is low decrease timeing value but limit minium to 16
TimeDelay := (TimeDelay- 1) #> 16 'To prevent cog lockup
waitcnt(clkfreq /20 + cnt) 'Wait 1/20 of a second
Dat
org
PulseDelayStart xor DIRA, InMask ' Set crank to input
or DIRA, OutMask 'Set coil to output
xor OUTA, OutMask 'Set the output pin to low
PulseDelay waitpeq InMask, InMask 'Wait for the Pin to be high
waitpne InMask, InMask 'Wait for the pin to be low TDC
rdlong _nextWait, par 'Get the newest timeing value
add _nextWait, cnt 'Add current counter value to it
waitcnt _nextWait, _MS2 'Wait the timeing amount and add 2 ms delay
or OUTA, OutMask 'Turn on the coil out pin
waitcnt _nextWait, #0 'Wait 2 ms , 0 Delta for next wait _nextWait
xor OUTA, OutMask 'Turn off coil pin.
jmp PulseDelay 'Jump back up to start
_nextWait res 1 'Reserve 1 long for the wait command
_ms2 long ms2 'Constant 2 milisecond pulse, num of clk cycles
InMask long |< PinIn ' A mask for the input pin
OutMask long |< PinOut 'Output pin mask
Thank you TJ
Aprilia RS250
For setting bits you use the or, for clearing bits you should use the andn.
2. You should have the res behind the longs. I'm not sure if res will be resolved correctly by the spin compiler. The intention of res is to reserve a long which can be used by the symbol, but without wasting longs in HUB-RAM. So, that symbol is only available in the COG. I'd guess that this will overwrite your _ms2.
3. In the spin-part you should use ina and ina
4. Your timing will be more accurate if you store the cnt-value before you rdlong, as rdlong can take 7 to 22 cycles.
5. dira[noparse][[/noparse]2]~
··· dira[noparse][[/noparse]3]~
Just for clarification. It won't change anything in the functionalíty, as it dira is initialized as input.
6. waitpeq and waitpne should propably have the ina as source, otherwise the first one will be always true, the second one will be never true. That looks like an endless loop ;o)
Post Edited (MagIO2) : 4/1/2009 8:38:44 PM GMT
Phil
Thanks, I do pasm get good wait 2 months and forget everything.
MagIO2
For 1 and 5. It makes it more universal when I go to use it later, ensuring that the pin states are correct, just preferance. Is there a reason against this other than lost start up cycles?
Note on 1. Im out of pratice, thanks.
For 3. The fourms remove the·'[noparse]/noparse] 3[color=white]·[/color or·'[noparse][[/noparse] 4 ]. on me sometimes Havent figured out why yet.
For 6. I am winning the dumbass award. Thanks
For 2. Im not sure I get this one. If I do
I am not really understanding what you are telling me
OK current version, no sucess still.
Con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PinIn = 0 PinOut = 1 MS2 = (80_000_000/1_000) * 2 'A 2 Milisecond Delay obj Term : "serial_terminal" Var Long TimeDelay Pub Run TimeDelay := 1000 'Set a base value cognew(PulseDelayStart, @TimeDelay) 'Start a new cog w/ the asm program term.start 'Start the terminal dira[noparse][[/noparse]2]~ 'Set pin 2 to input dira[noparse][[/noparse]3]~ 'Set pin 3 to input repeat term.out(0) 'Clear terminal screen term.dec(TimeDelay) 'Print current timeing delay value if ina[noparse][[/noparse]2] == 0 'if pin 2 is low, increase timeing value TimeDelay++ elseif ina[noparse][[/noparse]3] == 0 'if pin 3 is low decrease timeing value but limit minium to 16 TimeDelay := (TimeDelay- 1) #> 16 'To prevent cog lockup waitcnt(clkfreq /20 + cnt) 'Wait 1/20 of a second Dat org PulseDelayStart andn DIRA, InMask ' Set crank to input or DIRA, OutMask 'Set coil to output andn OUTA, OutMask 'Set the output pin to low PulseDelay waitpeq INA, InMask 'Wait for the Pin to be high waitpne INA, InMask 'Wait for the pin to be low TDC mov _nextWait, CNT 'Get the current count before rdlong rdlong _delay, par 'Get the newest timeing value add _nextWait, _delay 'Add current counter value to it waitcnt _nextWait, _MS2 'Wait the timeing amount and add 2 ms delay or OUTA, OutMask 'Turn on the coil out pin waitcnt _nextWait, #0 'Wait 2 ms , 0 Delta for next wait _nextWait andn OUTA, OutMask 'Turn off coil pin. jmp #PulseDelay 'Jump back up to start _nextWait res 1 'Reserve 1 long for the wait command _delay res 1 'The delay from the hub _ms2 long ms2 'Constant 2 milisecond pulse, num of clk cycles InMask long |< PinIn ' A mask for the input pin OutMask long |< PinOut 'Output pin maskThoughts or ideas?
Aprilia RS250
I tried this a test program. Is my asm that far out of pratice? The following should simpily turn on a pin. That is connected to an led
Con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 LedPinNum = 4 Var Long StartPoint Pub Main StartPoint := LedPinNum 'Set the pin number to be correct dira[noparse][[/noparse]LedPinNum]~~ 'Test chip by turing on LED It comes on outa[noparse][[/noparse]LedPinNum]~~ waitcnt(clkfreq+cnt) 'wait 1 second outa[noparse][[/noparse]LedPinNum]~ 'Turn off led, start up asm cog cognew(LightOn, @StartPoint) repeat 'Forever repeat to keep chip running waitcnt(clkfreq+cnt) Dat org LightOn rdlong _PinNum, par 'Get the pin num from hub mov _PinMask, #1 'Set mask to 1 to shift shl _PinMask, _PinNum 'Move Left 1 to pin num or DIRA,_PinMask 'Make pin an output or OUTA,_PinMask 'turn on pin jmpforever jmp #JmpForever 'Just keep reapeting so it never stops _PinNum res 1 _PinMask res 1Yet it seems to do nothing. Also note In the main program I tried the waitpeq and waitpne both ways, with waitpne ina, Inmask and waitpne Inmask, inmask. No change
Thanks again all
Aprilia RS250
Post Edited (TJHJ) : 4/1/2009 9:50:56 PM GMT
You didn't read my rebuttal to MagIO2. Change your waits back to what they were.
waitpeq InMask, InMask 'Wait for the Pin to be high waitpne InMask, InMask 'Wait for the pin to be low TDCIs still causing me equivilent prop lock up.
Thanks for the help phil.
TJ
Aprilia RS250
Also, if you run your program through my formatter, your bracketed numbers will display okay. Try using it and post a complete current version of your code.
[b]Con[/b] [b]_clkmode[/b] = [b]xtal1[/b] + [b]pll16x[/b] [b]_xinfreq[/b] = 5_000_000 PinIn = 0 PinOut = 1 MS2 = (80_000_000/1_000) * 2 'A 2 Milisecond Delay [b]obj[/b] Term : "serial_terminal" [b]Var[/b] [b]Long[/b] TimeDelay [b]Pub[/b] [b]Run[/b] TimeDelay := 1000 'Set a base value [b]cognew[/b](PulseDelayStart, @TimeDelay) 'Start a new cog w/ the asm program term.start 'Start the terminal [b]dira[/b][noparse][[/noparse]­2]~ 'Set pin 2 to input [b]dira[/b][noparse][[/noparse]­3]~ 'Set pin 3 to input [b]repeat[/b] term.out(0) 'Clear terminal screen term.dec(TimeDelay) 'Print current timeing delay value [b]if[/b] [b]ina[/b][noparse][[/noparse]­2] == 0 'if pin 2 is low, increase timeing value TimeDelay++ [b]elseif[/b] [b]ina[/b][noparse][[/noparse]­3] == 0 'if pin 3 is low decrease timeing value but limit minium to 16 TimeDelay := (TimeDelay- 1) #> 16 'To prevent cog lockup [b]waitcnt[/b](clkfreq /20 + [b]cnt[/b]) 'Wait 1/20 of a second [b]Dat[/b] [b]org[/b] PulseDelayStart [b]andn[/b] [b]DIRA[/b], InMask ' Set crank to input [b]or[/b] [b]DIRA[/b], OutMask 'Set coil to output [b]andn[/b] [b]OUTA[/b], OutMask 'Set the output pin to low PulseDelay [b]waitpeq[/b] InMask, InMask 'Wait for the Pin to be high [b]waitpne[/b] InMask, InMask 'Wait for the pin to be low TDC [b]mov[/b] _nextWait, [b]CNT[/b] 'Get the current count before rdlong [b]rdlong[/b] _delay, [b]par[/b] 'Get the newest timeing value [b]add[/b] _nextWait, _delay 'Add current counter value to it [b]waitcnt[/b] _nextWait, _ms2 'Wait the timeing amount and add 2 ms delay [b]or[/b] [b]OUTA[/b], OutMask 'Turn on the coil out pin [b]waitcnt[/b] _nextWait, #0 'Wait 2 ms , 0 Delta for next wait _nextWait [b]andn[/b] [b]OUTA[/b], OutMask 'Turn off coil pin. [b]jmp[/b] #PulseDelay 'Jump back up to start _ms2 [b]long[/b] ms2 'Constant 2 milisecond pulse, num of clk cycles InMask [b]long[/b] |< PinIn ' A mask for the input pin OutMask [b]long[/b] |< PinOut 'Output pin mask _nextWait [b]res[/b] 1 'Reserve 1 long for the wait command _delay [b]res[/b] 1 'The delay from the hub▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Aprilia RS250
Post Edited (TJHJ) : 4/2/2009 12:04:48 AM GMT
Post Edited (Phil Pilgrim (PhiPi)) : 4/2/2009 1:15:14 AM GMT
Damn Its always the simple one, Ive spent so much time looking at the asm code. It works perfectly. Thank you so much for all of the help Phil and MagIO2
TJ
Aprilia RS250
