Help with spin to assembly conversion
I am trying to read ( get timming width of) a single pulse. When I did this in spin code the results were 5 time the o-scope width. I went to assembly:
CON
·_clkmode = xtall + pll16x
·_xinfreq = 5_000_000
Var
·Long xxx1
obj
·· num : "Numbers"
·· TV : "TV_Terminal
PUB Main
· cognew(@pulse,@xxx1)
· waitcnt(2_000_000 + cnt)
· Num.Init
· TV.Start(12)
· TV.Str(Num.ToStr(xxx1,Num#DDEC))
· TV.Out(13)
repeat
DAT
············· org 0
pulse······ mov· Mem,PAR
:loop······ waitpeq %0,25
············· waitpne %0,25
············· mov······xx1,cnt
··············waitpeq %0,25
············· mov yy1,cnt
············· sub· yy1,xx1
············· wrlong Mem,yy1
············· jmp···· :loop
xx1·· res· 1
yy1·· res· 1
Mem· res· 1
This does not work. Any comments?
[noparse][[/noparse]edit, I added a subject for you. Bean]
Post Edited By Moderator (Bean (Hitt Consulting)) : 3/30/2009 6:13:07 PM GMT
CON
Var
·Long xxx1
obj
·· num : "Numbers"
PUB Main
· Num.Init
· TV.Start(12)
· TV.Out(13)
repeat
DAT
············· org 0
xx1·· res· 1
yy1·· res· 1
Mem· res· 1
I also put in a pin change in the assembly ( hooked to an LED) and it does not get toggled.
I don't think the cognew is launching it.
It would also help for you to explain what you're trying to do. For example, what edge do you intend to use for the leading edge and trailing edge of your pulse?· Is this a single pulse or do you have several coming in?· If several, how close together are they?
Also consider that the cog counters may give you a better result since they can time a pulse to the nearest clock pulse, but need help from an assembler or Spin routine for set up and to read the count before the next one comes in.
Post Edited (Mike Green) : 3/30/2009 11:42:31 PM GMT
Thanks for your timely help!
Swampie777
Donald
The suggestions you made were incorporated. Additionally, I modified the first repeat do do 11 values.
91808 -0.0426%
91890 0.0467%
91861 0.0151%
91844 -0.0034%
91841 -0.0066%
91843 -0.0045%
91844 -0.0034%
91873 0.0282%
91844 -0.0034%
91841 -0.0066%
91829 -0.0197%
1010318
91847.09091
This was for a 1.148 ms pulse. I'm now curious as to how to further stabilize the counters.
I believe that more accuracy is possible.
Thanks for your help!
