select case
Could someone give me a little guidance please?
Using the Select Case command the max number of Cases is apparently 16 or 17. I have over 25 conditions I am testing. (Basically if x=1 go to this sub...through if x=25 go there.) Is there a better way than using one Select command to test 1-17 and 8 more if then commands for numbers 18- 25?
thanks so much
curtis.
thanks so much
curtis.
Can you post the code you currently have? It is easier to understand the program if we can look at it. It sounds like you might be able to use a LOOKDOWN/LOOKUP command,·because you can have 256 options in each of those commands.
Do·you have the BASIC Stamp Syntax & Refence Manual? If not, here is a link to the PDF free download.
BASIC Stamp Syntax & Refence Manual:
http://www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf
Respectfully,
Joshua Donelson
www.parallax.com
select x
case 1
goto a
case 2
goto b
case 3
goto c
case 4
goto d
case5
goto e
etc.
case 25
go to y
end select
I understand the case command is very efficient since the program stops once it finds a match and returns to the call that way it doesn't have to continue to check. thank you so much!
If x<10 then
select x
case 1
goto a
etc.
case 9
goto i
end select
endif
if x>=10
y=x
select y
case1
goto j
etc etc
It looks like you will want to use the Branch command. That would allow you to goto up to 255 different locations in your program. I think it would help if you post your code so you could get more help. It has been my experience that if you think there is a need for an excessive number of branches that there·could be fundemental changes·in the code that could make things much better.
So the clean option is - use ·LOOKUP.
Of course your workaroud ( fancy word for kluge ) would work just fine.
My solution - ON Index GOSUB - of course you need to make sure your Index is correct and build some dummies in your code.
Here is atest code.
Index VAR Byte
Main:
FOR· Index = 0 TO 25
· ON Index GOSUB Goto_sub,Goto_sub,Goto_sub,Goto_sub, Goto_sub,Goto_sub,Goto_sub,Goto_sub,· Goto_sub,Goto_sub,Goto_sub,Goto_sub, Goto_sub,Goto_sub,Goto_sub,Goto_sub, Goto_sub,Goto_sub,Goto_sub,Goto_sub, Goto_sub,Goto_sub,Goto_sub,Goto_sub,· Goto_sub,Goto_sub,Goto_sub,Goto_sub, Goto_sub,Goto_sub,Goto_sub,Goto_sub
NEXT
STOP
END
GOTO_SUB:
· DEBUG ? Index
RETURN
You would be able to use some IF...THEN statements to break up the SELECT...CASE; because·a program can not have more than 16 nested CASE. However you can break it up in parts and should work just fine if you wanted to go that route.
I attached some code that compiled just·fine if you wanted to go that·route. Mind the memory map though, just for sheer size of the program. Again there might be a way to do this·more efficient with a LOOKUP or·LOOKDOWN command; but maybe this will get you started.
Respectfully,
Joshua Donelson
www.parallax.com
[noparse][[/noparse]code]
' {$STAMP BS2p}
' {$PBASIC 2.5}
' this app receives asyncronous serial data via com port to run led indicators and 7 segment digital led displays for a flight simulator.
DATA_n1 CON 6 'first 7219 display module
LoadCS1 CON 5
CLK1 CON 4
DATA_n2 CON 3 'second 7219 display module
LoadCS2 CON 2
CLK2 CON 1
decode CON 9
brite CON 10
scan CON 11
switch CON 12
test CON 15
'~~~~~~~~~~~~~~~~~~~variables~~~~~~~~~~~~~~~~~~
serDataIn VAR Word '0-65535 or something
PINN VAR Byte '0-255
max_dat VAR Word
index VAR Nib
temp VAR Nib
nonZ VAR Bit
dispVal VAR Word
odd VAR index.BIT0
x VAR Byte
GO VAR Byte
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~initialize 7219~~~~~~~~~~~~~~~~~~
FOR x=0 TO 1 'repeat twice times for good measure
MAINIO
FOR index=0 TO 7
LOOKUP index,[noparse][[/noparse]scan,7,brite,1,decode,$FF,switch,1],max_dat 'toggle test1 or test0 o test but take out to run!!!!
SHIFTOUT Data_n1, CLK1,MSBFIRST,[noparse][[/noparse]max_dat]
IF odd=0 THEN noLoad1
PULSOUT LoadCS1,5
NoLoad1:
NEXT
FOR index=0 TO 7
SHIFTOUT Data_n2, CLK2,MSBFIRST,[noparse][[/noparse]max_dat]
IF odd=0 THEN noLoad2
PULSOUT LoadCS2,5
NoLoad2:
NEXT
PAUSE 1000
NEXT
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~zero~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
MAINIO
dispVal= 0 'blankit or zeroit here
FOR index=1 TO 8
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]index]
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]dispVal]
PULSOUT LoadCS2,5
PAUSE 100
NEXT
dispVal= 0
FOR index=1 TO 8
SHIFTOUT DATA_n1,CLK1,MSBFIRST,[noparse][[/noparse]index]
SHIFTOUT DATA_n1,CLK1,MSBFIRST,[noparse][[/noparse]dispVal]
PULSOUT LoadCS1,5
PAUSE 100
NEXT
comcheck:
MAINIO
'SEROUT 16, 17405,[noparse][[/noparse]"r"] ' stamp not sending(listening)
SERIN 16, 17405, 1000, SPST, [noparse][[/noparse]DEC serDataIn] 'baud rate very import bs2p has own!!!!
GO=serDataIN DIG(0)+(serDataIn DIG(1)*10)
SPST:
AUXIO
SELECT GO
CASE 11 'AP on/off
LOW 5
CASE 12 'AP on/off
HIGH 5
CASE 15 'HDGH off
LOW 10
CASE 16 'HDGH on
HIGH 10
CASE 17 'SPDH off
LOW 14
CASE 18 'SPDH on
HIGH 14
CASE 21 'APP off
LOW 7
CASE 22 'APP on
HIGH 7
CASE 23 'LOC off
LOW 6
CASE 24 'LOC on
HIGH 6
CASE 25 'VS off
LOW 9
CASE 26 'VS on
HIGH 9
CASE 27 'ALTH off
LOW 8
CASE 28 'ALTH on
HIGH 8
CASE 29 'gearup
LOW 3
HIGH 4
PAUSE 1000
HIGH 3
HIGH 4
' !!!!!!Select Stop here due to MAX # of Case=16
' IF GO=30 THEN 'geardown
' LOW 3
' HIGH 4
' PAUSE 1000
' LOW 3
' LOW 4
' ENDIF
' IF GO =31 THEN GOTO HDGDisplay '31 hdg 31 to 36031
' IF GO=32 THEN GOTO ALTDisplay '32 alt 32 to 65532 one word (byte) max
' IF GO=33 THEN GOTO ASPDisplay '33 ASP 33 to 65533 one word (byte) max
' IF GO=34 THEN GOTO VSDisplay '34 +VS 34 to 9934
' IF GO=35 THEN GOTO VSnegDisplay '35 -VS 35 to 9935
ENDSELECT
'GOTO HDGDisplay testing block only
'GOTO ALTDisplay
'GOTO ASPDisplay
'GOTO VSDisplay
'GOTO VSnegDisplay
PAUSE 50
GOTO comcheck
HDGDisplay:
MAINIO
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]6] 'code 36020 2-3-4 0=DIG0,6=DIG1,3=DIG3,7=DIG4,1=DIG5
temp=serDataIn DIG (2)
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]temp]
PULSOUT LoadCS2,5
PAUSE 50
temp=serDataIn DIG (3)
PULSOUT LoadCS2,5
PAUSE 50
temp=serDataIn DIG (4)
PULSOUT LoadCS2,5
PAUSE 50
GOTO comcheck
ALTDisplay:
MAINIO
SHIFTOUT DATA_n1,CLK1,MSBFIRST,[noparse][[/noparse]6] '99921 6-5-4 index
temp=serDataIn DIG (2) ' 2-3-4 0=DIG0,6=DIG1,3=DIG3,7=DIG4,1=DIG5
SHIFTOUT DATA_n1,CLK1,MSBFIRST,[noparse][[/noparse]temp]
PULSOUT LoadCS1,5
PAUSE 50
PULSOUT LoadCS1,5
PAUSE 50
PULSOUT LoadCS1,5
PAUSE 50
GOTO comcheck
ASPDisplay:
MAINIO
SHIFTOUT DATA_n2,CLK2,MSBFIRST, '99922 3-2-1 index
PULSOUT LoadCS2,5
PAUSE 50
PULSOUT LoadCS2,5
PAUSE 50
PULSOUT LoadCS2,5
PAUSE 50
GOTO comcheck
VSDisplay:
MAINIO
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]7] 'tells what digit
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]0] 'tells value to clock in
PULSOUT LoadCS2,5 'this zeros (the negative sign)
PAUSE 50
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]8] 'tells what digit
temp=serDataIn DIG (2) '7-8-1 17362=0=DIG0,6=DIG1,3=DIG3,7=DIG4,1=DIG5
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]temp] 'tells value to clock in
PULSOUT LoadCS2,5
PAUSE 50
SHIFTOUT DATA_n1,CLK1,MSBFIRST, 'tells what digit
temp=serDataIn DIG (3) '17360 0=DIG0,6=DIG1,3=DIG3,7=DIG4,1=DIG5
SHIFTOUT DATA_n1,CLK1,MSBFIRST,[noparse][[/noparse]temp] 'tells value to clock in
PULSOUT LoadCS1,5
PAUSE 50
GOTO comcheck
VSnegDisplay:
MAINIO
SHIFTOUT DATA_n2,CLK2,MSBFIRST,[noparse][[/noparse]10] 'tells value to clock in
PULSOUT LoadCS2,5 'this adds the negative sign
PAUSE 50
temp=serDataIn DIG (3) '9923 tells what digit
PULSOUT LoadCS2,5
PAUSE 50
PULSOUT LoadCS1,5
PAUSE 50
GOTO comcheck
'DIG 12 DIG(0)=2 DIG(1)=1
'DIG -1234 DIG(5)=0 DIG(0)=4 DIG(1)=3 DIG(2)=2 DIG(3)=1
' SPD HDG V/S ALT
'digit 1-16 left to right 1-2-3 4-5-6 7-8-1-2-3 4-5-6-7-8 for CS2 chip/CS1 chp second group
'value 10=- 0=0 1=1 2=2 3=3 ...
RETURN
Just as a future note, if you post complete code, normally it is easier for the reader if you use the attachement manager; unless it is just a snippet of code. Not a big deal a heads up
Respectfully,
Joshua Donelson
www.parallax.com
