MosFet's from BS2e
hmlittle59
Hello All,
I thought (Chris) or someone answered this for me but I could not find it. I want to turn on(5v) the base of a NPN MosFet chip (for 2 sec.) from my BS2e.
I will need an 1k resistor in series to protect the BS2e pin from to much current draw from the Mosfet and a 100k resistor from Base to Gnd to eliminate any false/noise spike turning on the NPN? Also the Body Size of the resistor(0805 smt) should not make a difference correct?
1) 1k ohms in series from BS2e to Base of Mosfet
2) 100k ohms from Base to Grd
3) Body size does not make a difference(1206 or 0805)...I want to use 0805 smt
thanks again
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks again
hmlittle59
To answer your questions:
1) A 1K resistor would work fine, although you probably don't need it because once the gate is "charged", the mosfet remains on, and no more current flows into the gate - unlike a BJT where current MUST flow through the base to keep it on.
2) You should probably use a resistor in that range(100k) from the GATE to SOURCE(probably ground). This is to ensure that the MOSFET stays off if the voltage is floating for some reason.
3) Considering there is VERY little power dissipated in the resistor(if you are switching at fairly low frequencies - < 10kHz), the resistor sizes can be as small as you want.
I hope that helps!
It's not quite correct to characterize a MOSfet as a resistance controlled by the gate voltage, though.· A resistor is perfectly linear, by definition, while a MOSfet is usually a little bit nonlinear.··At low source-drain currents it can be a lot nonlinear.· That's true with junction FETs, too, not just with MOSfets.· But as a design approximation, a resistance is often a good working assumption.
I concur that a series resistor isn't needed -- except that it can protect the chip's logic output in the case of a malfunction such as a shorted gate, and also protect it from large transient gate-charging currents.· Some big MOSfets have a lot of gate capacitance.· But a series resistor slows the switching down, which can increase transient heating in the MOSfet as it switches.· Life is full of compromises.
I'd use a resistor in series with the gate anyway, probably about 4.7K, though 100K would be OK too.· And I like the notion of a pulldown from gate to source for those times when the input (from a microprocessor) is in an input (floating)·state.· 100K may be OK, although it reduces the drive because of voltage division between the series and the pulldown resistors.· I'd probably use 4.7K and 470K respectively, so the drive reduction would be only 1%.· With 100K in both places, the drive would be reduced 50%, maybe too much.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 4/1/2009 1:45:17 AM GMT
thanks again
hmlittle59
