IR Signal
I'm looking to send an IR signal to two IR detectors.· Each IR detector will be associated with it's own LED.· For example the right IR detector associated·with a green LED and the left IR detector associated·with a red LED.· I want the detectors to compare the IR signal and if the right detector is receiving the stronger signal than the green LED would light up and likewise for the left detector and red LED.· I have built my own IR Beacon to do this.· I can make an led light up if·a detector·'sees' the IR signal but I don't know how to write the code to have two detectors compare the signal value.· I would appreciate any guidance accomplishing this.· I will be using a basic stamp.
So two thoughts for you. First, mount your two detectors slightly off-axis (non-parallel) in seperate optical enclosures so they can only see out through a limited window (aperture) and each one has a different angle of view. The two ranges will overlap in the center, when both detectors see your beacon. Off-center, only one will see the beacon. You'll want to make your baffles light-tight all around and paint them with non-reflecting ultra flat black spray paint. This can be painted posterboard or almost anything, but it needs to be optically opaque and non-reflecting.
Second, you could play the frequency sweep game, where your beacon sends IR tone IR bursts at ~32 Khz, 33, 34, 35,·36, 37,38, then repeats. These off-frequency bursts will eventually trigger your sensors,·and assuming they are identical sensors, the one with the best view (closer or aimed more directly at beacon) will trigger first (more off-frequency). Plenty of examples of this in· Boe-Bot & Scribbler code, where the robot emits an off-frequency signal sweep, looking for a reflection from nearby objects. The more off-frequency signal detected, the closer (or more IR reflective) an object is.
