I need your help
                    Hello, I am working in a project where I need to check the presence a buzzer; the buzzer works with a spectrum audible. I think, I can do it with a microphone, for example, when the buzzer is ringing the microphone recives the sound, of course, I will need to prepare the signal, but I have a·hypothesis, how the spectrum is audible, my·circuit·can be in fault with some sound its recive, isn't it?
How do you think????? I hope you understand me, because my English is bad.
Regards . . .
Regards . . .
R1 is used to provide an operating voltage if you're using an electet microphone that requires it.
Pretty much any general purpose NPN transistor can be used for the BC109C and pretty much any general purpose PNP transistor can be used for the BC212B. The diodes can all be any general purpose switching diode like the 1N4148 or 1N914. You can leave out the relay (RL1) and its protective diode.
Post Edited (Mike Green) : 3/26/2009 5:03:07 AM GMT
What is your opinion?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks and advance
