Question to Tap your expirence
I've worked with allot of processors over the years. Mostly but not entirely on the intel side. Starting with the 6502's, working through that into Z-80's, the 8080's,·8085's·and 5 digit variants of those, and the Atmel processors. Looking at my stack of fried props, it seems to me like the prop is a little more fragile than other processors I've worked with. I just don't remember feeling like my development efforts in the past required such a backstock of fresh chips. I don't want to take away from the capabilities and innovation of the chip but this issue·has been·bothering me a bit.
I have allot of respect for the population of this forum. What's the collective opinion?
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Jim-
to trying things with the Propeller, I haven't managed to fry one yet. Granted, I'm observing
rules regarding power input and I/O, but I don't have any reservations in regard to testing
conditions outside the box just to see what happens.
The Propeller appears very robust from this angle.
OBC
New to the Propeller?
I have a DYS board with just a prop, crystal, EEPROM and MAX2323 and some DYS extensionboards
I did a lot of testing with this boards combined with breadboards.
And I have a PPDB and these are the only TWO props that I have and both are still working properly for two years now.
So I got the impression you seem to have habits while developing where you give the chips a quite great amount of EMV and other stress
best regards
Stefan
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
I've also got a Proto board and haven't had any problems with that. There has been the occasional chip failure with them, but I get the
impression that they are very reliable.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 3/27/2009 5:39:44 PM GMT
I discount tales of woe along the lines of, "my chip evaporated leaving nothing behind except its legs in the socket when I connected a car battery to its power pins", because that's the sort of thing which is likely to happen with any chip
I haven't used Propellers frequently enough to become blas
Leon
1 i accidentally connected 12V to the power pin.
1 for some reason started giving low only on 10 of the pins. The same 10 i was using to run 4x16 decoders with at high speeds. no clue why that failed.
1 i soldered on backwards and it broke while trying to desolder. Not really a failure but it isn't working.
All being the small QFP type.
I don't blame parallax for any of them. 2 are definitely my fault and I probably abused the middle one some how.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
The thing must be bomb proof! ( he says holding all things crossed )
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
