Do I need pull resistors
Hi all
·I'm interfacing a 74ls170 4 x 4 register file for memory of 4 words of 4 bits each to a 74ls157 data selector.Then reading the words back to the PDB's readout.
Question; The 74ls170 has open collector outputs, will i need pullup resistors on the connections whe're they connect the 74ls157's inputs.
allie
allie
One way to do it would be to use three 74LS157 devices, of course.· If you do that, you won't need pullups on the 74LS157 that is fed by the other two 74LS157s, but you will·need pullups on the two 74LS157s that are fed by the 74LS170.
· -- Carl, nn5i@arrl.net
Still, I'd use the pullups. You might decide later to switch to 74HCxxx parts.
P.S. Like Carl, I also wonder about the logic of your proposed circuit.
Post Edited (Phil Pilgrim (PhiPi)) : 3/28/2009 7:08:57 PM GMT
Even among the 74LSxx devices from NSC, there are differences in the input circuits from one 74LSxx device to another.· For example, 74LS00 used a different input from that used by 74LS54.
So the Wikipedia article is not quite correct.
Some 74LSxx devices will work from open-collector outputs without external pullups, but some will not -- and even those that will work will suffer a loss in switching speed.
Use the pullups.· 1500 ohms ought to work fine, and be fast and reliable.
Edit:· added the word some at the start of second sentence of first paragraph.
Post Edited (Carl Hayes) : 3/28/2009 7:33:55 PM GMT
·I am using 2 74ls157's which are switched between busses A and B by a 74ls76, in toggle mode. I'm using the 74ls76 because I'm combining a 74ls170 and a 74ls670 and a 74ls90 into two 74ls157's and outputting these into a74ls48 for readout and also into a 74ls541 for an eight led readout of the binary form. For now the read addresses I'm doing it manually, but am planning to do it auto later.
when I get time I'll send·a schmatic. I'm new to the schmatic drawing tools,so it will take me some time to get it drawn,but I will try.
allie
