RFID Issues with MSP430 using the UART interface
Hi everyone,
Recently I bought the RFID reader from here but I have been unable to make it work the way i would like to. I'm using UART to connect with the RFID and it looks like I'm able to read information from the tags by using the code below (I get a mix of what I would expect with some random stuff), but I'm not sure on how to receive the whole string of a tag. Any ideas?? Thanks in advance!
#include "msp430x54x.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD;
P10SEL = 0x30; // P3.4,5 = USCI_A0 TXD/RXD
UCA3CTL1 |= UCSWRST; // **Put state machine in reset**
UCA3CTL1 |= UCSSEL_1; // CLK = ACLK
UCA3BR0 = 0x0D; // 2400 (see User's Guide)
UCA3BR1 = 0x00; //
UCA3MCTL |= UCBRS_6+UCBRF_0; // Modulation UCBRSx=6, UCBRFx=0
UCA3CTL1 &= ~UCSWRST; // lize USCI state machine**
UCA3IE |= UCRXIE; // Enable USCI_A1 RX interrupt
__bis_SR_register(LPM3_bits + GIE); // Enter LPM3, interrupts enabled
__no_operation(); // For debugger
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCI_A3_VECTOR
__interrupt void USCI_A3_ISR(void)
int i;
char test[noparse][[/noparse]12];
switch(__even_in_range(UCA3IV,4))
case 0:break; // Vector 0 - no interrupt
case 2: // Vector 2 - RXIFG
// USCI_A1 TX buffer ready?
while (!(UCA3IFG&UCTXIFG));
for(i=0; i<13; i++)
test[i] = UCA3RXBUF;
//UCA3TXBUF = UCA3RXBUF; // TX -> RXed character
break;
case 4:break; // Vector 4 - TXIFG
default: break;
[/i]
Make sure your MSP430 UART timing is correct. A timing mismatch will certainly cause random character errors.
#include <msp430x54x.h> #include <stdio.h> void main(void) { int temp = 0; int hexArray[noparse][[/noparse]12]; //recieved string hex values(ascii) char strArr[noparse][[/noparse]12]; //array that will contain actual string int i = 0; int startByte = 0; int stopByte = 0; WDTCTL = WDTPW + WDTHOLD; // Stop WDT P10SEL = 0x30; // P3.4,5 = USCI_A0 TXD/RXD UCA3CTL1 |= UCSWRST; // **Put state machine in reset** UCA3CTL0 = 0x20; UCA3CTL1 |= UCSSEL_1; // CLK = ACLK UCA3BR0 = 0x0D; // 2400 (see User's Guide) UCA3BR1 = 0x00; UCA3CTL1 &= ~UCSWRST; // Initialize USCI state machine** UCA3IE |= UCRXIE; // Enable USCI_A1 RX interrupt // Mainloop while (1){ __bis_SR_register(LPM3_bits + GIE); // Enter LPM3, interrupts enabled while (!(UCA3IFG&UCTXIFG)); // USCI_A1 TX buffer ready? temp = UCA3RXBUF; // RXBUF0 to TXBUF0 if(i<12){ hexArray[i] = temp; i+=1; } if(i>=12) { i = 0; } } } #pragma vector=USCI_A3_VECTOR __interrupt void USCI_A3_ISR(void) { _BIC_SR_IRQ(LPM3_bits + GIE); //exit low power mode } [/i]Any help would really be appreciate it.
