How to use extra EEPROM for storage?
Hi,
· I'd like to use an external EEPROM for data storage.· I have a couple 93LC66A's, but there are no examples on how
to write a program for the BS2.· Is using a 93LC66 a good choice or is there a better EEPROM to use for external storage?
Any assistance would be greatly appreciated.
Doug
Doug
· I have a 93LC66A.· I'm trying to convert old BS1 code to work with my BS2.· It's very painful at this point.· My overall goal for data storage is to be able to use my PING DAR with COMPASS and store angles and distances in EEPROM.· I'm trying to find a good EEPROM solution.· It appears the StampMEM was taking off the market.· I'm not sure if the USB Memory module will work.· I only was trying to use the 93LC66A because I had two of them sitting around.· If there is something that is better for what I want, I'll try it.· For right now I'm just trying to get code to work with the 93LC66A.· Once again, any assistance would be greatly appreciated.
Doug
· Here is the best I've found.· It appears to erase the chip.· I'd like to take data from a debug input and write it to the chip, them read it back.· Once again, any assistance would be greatly appreciated.
Doug
Here is some DEMO code I just put together based on the BS1 application notes - #13. The DEMO code basically runs through a few patterns by writing them to the EEPROM and then reads the value back for a Pass/Fail indication.
Beau Schwabe
IC Layout Engineer
