stored variables — Parallax Forums
stored variables
Earl FosterEarl Foster Posts: 185
edited 2009-03-28 14:04 in Propeller 1
I am trying to read/write a variable from/to a specific memory location that will be retained when there is a power cycle or reset.· The variables will change throughout the life of the program so I figure I can assign a seed value the first time and then read and write the changing·variable there after.· What is the best approach to accomplish this task?
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
  • ericballericball Posts: 774
    edited 2009-03-27 16:31
    If you want the variable to survive a Propeller power down or reset, you're going to have to store it in an off-chip EEPROM or equivalent.
    edited 2009-03-27 16:52
    Earl Foster,
    Andy Lindsay wrote an excellent description on how to do this very thing. The only caveat is that if you re-program from the Propeller IDE, then the EEPROM locations value will be lost. But even then if you substitute a larger EEPROM and write to the upper 32K then even a Propeller IDE download can't touch this area of EEPROM ... only the EEPROM object within the Propeller can see it.
    Check out this link Andy Lindsay wrote:
    http://forums.parallax.com/forums/default.aspx?f=25&m=219237
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/28/2009 5:49:56 AM GMT
  • Earl FosterEarl Foster Posts: 185
    edited 2009-03-27 18:25
    Thanks, I figured there was a way. I will look into that thread.
    WWW.HAPB.NET
  • mparkmpark Posts: 1,336
    edited 2009-03-28 00:44
    Beau, which part of the text you quoted isn't exactly true?
    edited 2009-03-28 05:53
    mpark,
    I apologize... I misread your post. For some reason the "...off-chip EEPROM or equivalent" didn't register with "...surviving a Propeller power down or reset".
    I edited my earlier post
    Beau Schwabe
    IC Layout Engineer
    edited 2009-03-28 07:32
    You weren't quoting me so you needn't apologize to me. I was just wondering if I was missing something. Thanks for clearing that up.
    edited 2009-03-28 13:32
    Actually, you make a good point. Since the IDE can overwrite the low 32K of the boot EEPROM, using that space for temporary storage is not ideal.
    Well it worked like a champ. Thanks
    WWW.HAPB.NET
