Question to Tap your expirence
CannibalRobotics
I've worked with allot of processors over the years. Mostly but not entirely on the intel side. Starting with the 6502's, working through that into Z-80's, the 8080's,·8085's·and 5 digit variants of those, and the Atmel processors. Looking at my stack of fried props, it seems to me like the prop is a little more fragile than other processors I've worked with. I just don't remember feeling like my development efforts in the past required such a backstock of fresh chips. I don't want to take away from the capabilities and innovation of the chip but this issue·has been·bothering me a bit.
I have allot of respect for the population of this forum. What's the collective opinion?
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Jim-
to trying things with the Propeller, I haven't managed to fry one yet. Granted, I'm observing
rules regarding power input and I/O, but I don't have any reservations in regard to testing
conditions outside the box just to see what happens.
The Propeller appears very robust from this angle.
OBC
New to the Propeller?
I have a DYS board with just a prop, crystal, EEPROM and MAX2323 and some DYS extensionboards
I did a lot of testing with this boards combined with breadboards.
And I have a PPDB and these are the only TWO props that I have and both are still working properly for two years now.
So I got the impression you seem to have habits while developing where you give the chips a quite great amount of EMV and other stress
best regards
Stefan
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
I've also got a Proto board and haven't had any problems with that. There has been the occasional chip failure with them, but I get the
impression that they are very reliable.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 3/27/2009 5:39:44 PM GMT
I discount tales of woe along the lines of, "my chip evaporated leaving nothing behind except its legs in the socket when I connected a car battery to its power pins", because that's the sort of thing which is likely to happen with any chip
I haven't used Propellers frequently enough to become blas
Leon
1 i accidentally connected 12V to the power pin.
1 for some reason started giving low only on 10 of the pins. The same 10 i was using to run 4x16 decoders with at high speeds. no clue why that failed.
1 i soldered on backwards and it broke while trying to desolder. Not really a failure but it isn't working.
All being the small QFP type.
I don't blame parallax for any of them. 2 are definitely my fault and I probably abused the middle one some how.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
The thing must be bomb proof! ( he says holding all things crossed )
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
