stored variables
I am trying to read/write a variable from/to a specific memory location that will be retained when there is a power cycle or reset.· The variables will change throughout the life of the program so I figure I can assign a seed value the first time and then read and write the changing·variable there after.· What is the best approach to accomplish this task?
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
WWW.HAPB.NET
Andy Lindsay wrote an excellent description on how to do this very thing. The only caveat is that if you re-program from the Propeller IDE, then the EEPROM locations value will be lost. But even then if you substitute a larger EEPROM and write to the upper 32K then even a Propeller IDE download can't touch this area of EEPROM ... only the EEPROM object within the Propeller can see it.
Check out this link Andy Lindsay wrote:
http://forums.parallax.com/forums/default.aspx?f=25&m=219237
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 3/28/2009 5:49:56 AM GMT
WWW.HAPB.NET
I apologize... I misread your post. For some reason the "...off-chip EEPROM or equivalent" didn't register with "...surviving a Propeller power down or reset".
I edited my earlier post
Beau Schwabe
IC Layout Engineer
WWW.HAPB.NET
