4-bit switch
I am using a 4-bit switch·to adjust timing.· The below procedure is called with each loop of the program and it works without any problems but I wonder if there was a better way of programming it.· A more efficient way.· It is pretty straightforward with only 4 bits but if I need a 5-bit or 6-bit switch the code starts to get pretty long and would be easy to mess up the binary count.
Trying to get better at coding so I was just wondering.
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
Pub Get_Timing
case ina[noparse][[/noparse]21..24]
%0000: maxtime:= 30
%0001: maxtime := interval * 1
%0010: maxtime := interval * 2
%0011: maxtime := interval * 3
%0100: maxtime := interval * 4
%0101: maxtime := interval * 5
%0110: maxtime := interval * 6
%0111: maxtime := interval * 7
%1000: maxtime := interval * 8
%1001: maxtime := interval * 9
%1010: maxtime := interval * 10
%1011: maxtime := interval * 11
%1100: maxtime := interval * 12
%1101: maxtime := interval * 13
%1110: maxtime := interval * 14
%1111: maxtime := interval * 15
WWW.HAPB.NET
How about something like this?
Pub Get_Timing|temp temp := ina[noparse][[/noparse]21..24] if temp <> 0 maxtime := interval * temp else maxtime := 30▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
WWW.HAPB.NET
Post Edited (Phil Pilgrim (PhiPi)) : 3/27/2009 7:16:46 PM GMT
I'll happily admit to still learning SPIN but something like this may well be faster...
maxtime := 0 if ina[noparse][[/noparse]21..24] == 0 maxtime := 30 if ina[noparse][[/noparse]21] == 1 maxtime := interval if ina[noparse][[/noparse]22] == 1 maxtime := maxtime + interval << 1 if ina[noparse][[/noparse]23] == 1 maxtime := maxtime + interval << 2 if ina[noparse][[/noparse]24] == 1 maxtime := maxtime + interval << 3-Phil
See attached timing code.
Original code - 38.2us
Beau's Code· - 35.6us
Phil's Code··· -·25.4us
Brian's Code· -·78.0us
Beau Schwabe
IC Layout Engineer
WWW.HAPB.NET
Post Edited (Earl Foster) : 3/27/2009 8:00:29 PM GMT
