Battery Paks
I have 2 TL-5242/W Rechargeable Lithium battery backs but the datasheet does not say what max current draw is. Anyone know what the draw on these are? or know some small battery packs that can handle 2A draw. I only need to keep it running at full current for 20 min or so.
I can fit 4 Lithium AA in but they use up all my space and are not rechargeable.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
A better bet is one of the lithium ion batteries. Check out batteryspace. The 18650 cells have a capacity of around 1300 mAh, and peak current of around 2 amps.
Tracy Allen
www.emesystems.com
Any suggestions on how to build a charging circuit?
This pack looks perfect. should give me an hour at full draw and days at minimum.
the 18650 is the same battery used in the Spyder II lazer.
http://www.wickedlasers.com/lasers/Spyder_II_GX-26-0.html
i.e. my application is plugged into wall uses this ic to charge my battery pack. my dual input switching supply auto switch between the 12V wall and the 7.4V battery back when the wall goes dead. When power is regained it charges the battery and leaves it there until the next time the power goes out.
