SXB Square Wave
Hello,
I have been trying Terry's sweep code with no luck. I am sure it me doing something wrong. I used a scope and an LCR circuit to see if I could get to resonance. If I use the interrupt without sweep at one frequency, it works.
Device SX28, Oschs2, Turbo, OptionX, StackX
Freq 50_000_000
OutPin Pin RA.0 Output
reload VAR BYTE
Interrupt NOCODE
OutPin =~ OutPin
Returnint reload
Program Start
Start:
FOR reload = 139 TO 111 STEP -1
PAUSE 1000 ' CHANGES SWEEP SPEED
NEXT
GOTO Start
End
I am trying to get resonance but the square wave produced is not accurate enough.
Thanks for any hints.
Cenlasoft
Freq 50_000_000
reload VAR BYTE
Interrupt NOCODE
OutPin =~ OutPin
Returnint reload
Program Start
Start:
NEXT
GOTO Start
End
Cenlasoft
It is very possible that you don't have enough resoultion to get resonance. But with a 50MHz clock you can only vary the ON/OFF time by a minimum of 20nSec.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
