Mystery Sale extended through 4:30 p.m. (PDT) - SALE IS OVER
Parallax.com Mystery Sale! - From 10:00 a.m. to 4:30 p.m. (PDT)
DIRECTIONS: Find the mystery product by navigating through the related products in the store on the Parallax.com site.
You should move from one product page to the next through the related products at the bottom of the page (see screen shot below). If you don’t see the footprints you have lost your path!
HERE ARE YOR CLUES. GOOD LUCK!
1. Start here: This plug provides a USB-to-serial port connection that is convenient for microcontroller programming and communication. Answer: Prop Plug
2. Next (related product): This device is capable of asynchronous communication at up to 3 M baud with both 3.3-volt and 5.0-volt devices such as the Propeller and BASIC Stamp. Answer: Prop Clip
3. Next (related product): It’s your only other choice available. Don’t backtrack, keep moving forward! Answer: Spin Stamp
4. Next (related product): Use this kit with your microcontroller to build projects. Answer: Board of Education Full Kit (Serial)
5. Next (related product): This serves as the brains inside many electronics projects and applications. Mystery Sale Answer: BASIC Stamp 2p24!
FINE PRINT: Online special only. Limit one "Mystery Sale!" product per customer per day. Mystery Sale will list for two hours or until pre-determined max number of product have been sold (whatever comes first). Sale begins at 10:00 a.m. (PDT) on 03/25/09 and goes until 4:30 p.m.
Post Edited (Jen J. (Parallax)) : 3/25/2009 11:27:37 PM GMT
I thought it should be the Parallax USB to Serial (RS-232) Adapter ·or Parallax USB to Serial (RS-232) Adapter with Cable but neither seem to work.
www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/CategoryID/19/List/0/SortField/0/Level/a/ProductID/398/Default.aspx
Cheers, JJ
I bet the hint is the little footprints on the items.
If this is it then I followed all the clues, but I already own one of them.
Bummer, i would really like to have gotten a Propeller Education Kit instead.
Shawn Lowe
When all else fails.....procrastinate!
I snagged mine..great price!!·
