some Question with i2p command
If i have tow Ultrasonic Range Finder(SRF02) and BS2pe.
How should i use i2c this command to make two·Ultrasonic Range Finder·to display the result by turn.
Here is some example code from Parallax
Mike2545
This message sent to you on 100% recycled electrons.
Values for Pin Pin = 0 Pin = 8
I/O Pin
Arrangement
0: Serial Data (SDA) pin
1: Serial Clock (SCL) pin
OR
8: Serial Data (SDA) pin
9: Serial Clock (SCL) pin
NOTE That this information was given by the same manual that you have !
Now .. I don't understand your question, what do you mean by display the result by turn ???
