Nice Buck/Boost Converter chip for Propeller
I was looking over some parts from TI, and came across THIS. It's a buck/boost converter chip that boasts 96% efficiency, and can boost voltages as low as 1.9V up to 3.3V for the propeller or other devices. Also, it can output up to 1.2A. Pretty beefy IMO. Oh, and Quiescent current at 50uA. Seems great for low power applications.
I might order a few of these, and brew some PCB's up for them. If anyone wants one, let me know.
Cheers!
Paul Rowntree
Post Edited (Dr_Acula (James Moxham)) : 3/22/2009 11:12:24 AM GMT
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Single Board Computer·using the TriBladeProp board (ZiCog Z80 Emulator)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
if any want I will assemble some
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
As for the idea of power loss when the chip switches from buck to boost, or vise versa, the datasheet says it's automatic. I assume that with adequate capacitors, the transition wouldn't cause a problem since it happens so quickly(microseconds). I'll try and make a few breakout boards and see how they work.
Treelab, are you seriously complaining about 800mA??? 800mA coming out of a 3x3mm package? I was amazed at the current... [noparse]:)[/noparse]
Cheers!
Paul Rowntree
I'm interested in getting 3.3V and 5V from two batteries. Something that replaced a TO220 reg would be cool. There was a similar one I found that stepped up from one nicad. I can't find the product number right now. Dual cell would be fine though because it drops out at 1.8V so it would stop working when the first cell goes flat - which would prevent reverse polarity on the cell which is the #1 cause of premature failure of rechargeables.
Post Edited (Dr_Acula (James Moxham)) : 3/23/2009 5:00:52 AM GMT
2 modules is my minimum and is 30 can + parts
100 modules is 12 + parts
Quantity of 10 meaning in total I need to sell 10 not that you need to buy 10 yourself. So anyone interested? If I send out for PCB Tuesday I will be able to ship next Monday(March 30)
Will make both 3.3V,5V, and variable models
Modules are fully assembled and tested.*
*Variable model requires you soldering on two 0603 resisters for reference voltage.
JMH
EDIT: 2nd picture is the most recent. I had to change the inductor to a through-hole component.
Post Edited (Philldapill) : 3/24/2009 12:04:11 AM GMT
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I just figured out I can produce this for $12US if I can make 25 of each. Though it would be a 2 week turn around not my normal 1 week.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
