Code for Resetting PSC
I'm trying to use 2 switches to position my servos via the PSC.
When a change in switch status occurs, the servos does not respond. They will only move after I've pressed the reset button on the PSC.
Is there any code that I can use to reset the PSC withotu manually resetting it?
GOTO Main
not with
RETURN
there's a soft buzzing sound coming from the PSC when it's not responding. the green indicator is ON, meaning that comms is good.
Either a manual reset or re-inserting the +5V in to the breadboard will do the trick. The thing is I'm trying to use RF to send in the signals.
I'm thinking of using transistor to control the +5V signal. Any ideas?
Chris Savage
Parallax Engineering
