Using COGINIT to exit a WAITPEQ 'hang up'
The Prop manual says, pg 4-35, COGINIT "...can be used to stop and restart an active cog in one step..."
If one has assembly code hung up waiting for a WAITPEQ to match I/O pins designated state, will COGINIT truely remove it from the WAITPEQ instruction? If so, how much time does it take to effect the 'stop and restart' action?
Has anyone used COGINIT to exit a WAITPEQ condition? If so what are any details other than the COGINIT to accomplish this? Thanks for any help on this.
Harley Shanko
Harley Shanko
COGSTOP is fast, but leaves the cog in a stopped state.
You're probably wanting to force WAITPEQ/PNE to stop waiting and there's really no way to do that other than to satisfy the wait condition. You're better off not using WAITPEQ/PNE and using some instruction like TEST in a tight loop. It would leave the cog running, but you can control the exit condition.
I'm looking for a comparison in as few clock cycles as possible. Maybe a TEST in a tight loop would accomplish what's needed that WAITPEQ can't exit.
Harley Shanko
I'd love to see it faster, but off the top of my head 12 cycles is about as quick as I can manage
Cardinal Fang! Fetch the comfy chair.
pintest test mask,ina wz
IF_NZ DJNZ loop, #pintest
Oh to be able to latch the value of cnt into a register on the change of state of a pin...
You could do that with the Prop, using one counter, if the input doesn't have rapid-fire transients. All you have to do is set the counter to count up (frqx := 1) under the current pin state and stop counting when it changes. Then set its phsx so that it will equal (and thus track) cnt. Once the pin changes, you will need to read read phsx before it changes back.
With an external, resettable, D-type flip flop (e.g. 74HC74), you could use this technique to capture any pulse, no matter how fleeting.
I'm moving ahead with using the WAITPEQ. Plus using COGINIT and COGSTOP to escape the 'hang-up' for the 'no match' situation. The crude test steps I've used so far appear to make WAITPEQ far superior.
I have a 17-bit value to compare for a breakpoint, and can implement the COGSTOP and COGINIT from keypad commands presently in use to escape and restart. The delay to restart is no problem.
Harley Shanko
