Eyecancer
Is this forum themeable?
And especially: Is there a theme or skin or whatsoever without the childish animated smileys?
I get eyecancer!
Coming soon: Neat sig with bells and whistles!
I get eyecancer!
Unfortunately not, there is only one look for the time being for the forums. The smileys are only if someone goes to Post Reply instead of Quick Reply. Sorry for any inconvenience.
Respectfully,
Joshua Donelson
www.parallax.com
The forum's visual style is defined by the style sheet located here: forums.parallax.com/forums/styles/dotNetBB/css/style.css. Most browsers will let you specify a local style sheet on a per-site basis if you don't like the one provided by the site's host. You could simply copy the default style sheet, make whatever changes you want, save it on your PC, then specify it as a user style for the forum. I've experimented with this and had some success replacing the default font in [noparse][[/noparse]code] blocks. You won't be able to get rid of the smileys though.
Excellent, I was unaware that was an option. Upon·further digging, it looks like there are some pre-formatted styles also; Under Edit Options on the control panel. Sorry for the mis-information about the styles Yeti.
Respectfully,
Joshua Donelson
www.parallax.com
Post Edited (Joshua Donelson (Parallax)) : 3/20/2009 6:26:43 PM GMT
