Javelin Beginner Help (Servos)
I just started using the javelin stamp and don't know how to program a servo to move. I tried the example program but it didn't work. Can anyone post a sample program. I just want the servo to move
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
public class ServoControl {
static PWM servo = new PWM(CPU.pin12,173,2304);
public static void main() {
System.out.println("Welcome to Servo Control: ");
System.out.println(" r - right");
System.out.println(" l - left");
System.out.println(" c - center");
while (true) {
switch ( Terminal.getChar() ) {
case 'r':
servo.update(130,2304);
break;
case 'l':
servo.update(220,2304);
break;
case 'c':
servo.update(173,2304);
break;
If you read page 72 of the javelin manual (http://www.parallax.com/tabid/443/Default.aspx), it suggests that you must connect VM to either Vdd or Vin to supply the servo port with motor power. I see from your photo that this is not done.
Try it [noparse]:)[/noparse]
Adam Smith
