Help Connecting 2 bs2p40's through an eeprom
I am using the following programs to get 2 bs2p40s to communicate via an eeprom and i was wondering if anyone could tell me why this is not working.
The first program is for the master stamp that sends out the value that the slave stamp will read out.
1st (Master):
' {$STAMP BS2p}
' {$PBASIC 2.5}
inP·· PIN 15
outP· PIN 14
v VAR Byte
y VAR Byte
x VAR Byte
Setup:
· HIGH outP····················· ' Set pin high to be a serial port
· PAUSE 100······················ ' Pause for Serial LCD to initialize
start:
DO
IF outP = 1 THEN
· v = 63
· I2COUT 0, $A0, 0\3, [noparse][[/noparse]DEC v]
· DEBUG "out is ",DEC v
· PAUSE 100
· outP = 0
· PAUSE 100
· LOW outP
ELSE
· GOTO start
ENDIF
LOOP
2nd (Slave):
' {$STAMP BS2p}
' {$PBASIC 2.5}
Lcd············ PIN···· 7
inP············ PIN···· 14
outP··········· PIN···· 15
LcdCls········· CON···· $01···· ' clear the LCD
LcdHome········ CON···· $02···· ' move cursor home
LcdCrsrL······· CON···· $10···· ' move cursor left
LcdCrsrR······· CON···· $14···· ' move cursor right
LcdDispL······· CON···· $18···· ' shift chars left
LcdDispR······· CON···· $1C···· ' shift chars right
LcdDDRam······· CON···· $80···· ' Display Data RAM
LcdCGRam······· CON···· $40···· ' Character Generator RAM
LcdLine1······· CON···· $80···· ' DDRAM address of line 1
LcdLine2······· CON···· $C0···· ' DDRAM address of line 2
baud··········· CON···· 1021
v VAR Byte
x VAR Byte
y VAR Byte
Setup:
· HIGH Lcd····················· ' Set pin high to be a serial port
start:
DO
IF inP = 0 THEN
· I2CIN 0, $A1, 0\3, [noparse][[/noparse] DEC x]
· PAUSE 50
· WRITE 0, x
· READ 0, x
· DEBUG DEC x,CRSRRT
· SEROUT Lcd, baud, [noparse][[/noparse]24,12,17]
· PAUSE 100
· SEROUT Lcd, baud, [noparse][[/noparse]DEC x]
· PAUSE 100
· HIGH inP
ELSE
· GOTO start
ENDIF
LOOP
The SDA pin on the EEPROM is connected to pin 0 on both stamps.
The SCL pin on the EEPROM is connected to pin 1 on both stamps.
WP, A0, A1, A2 and Vss on the EEPROM is connected to the Vss of both stamps.
Vdd on the EEPROM is connected to the Vdd of both stamps.
1st (Master):
' {$STAMP BS2p}
' {$PBASIC 2.5}
inP·· PIN 15
outP· PIN 14
v VAR Byte
y VAR Byte
x VAR Byte
Setup:
start:
DO
IF outP = 1 THEN
· v = 63
· PAUSE 100
· outP = 0
· PAUSE 100
· LOW outP
ELSE
· GOTO start
ENDIF
LOOP
2nd (Slave):
' {$STAMP BS2p}
' {$PBASIC 2.5}
v VAR Byte
x VAR Byte
y VAR Byte
Setup:
start:
DO
IF inP = 0 THEN
· PAUSE 50
· WRITE 0, x
· READ 0, x
· PAUSE 100
· PAUSE 100
· HIGH inP
ELSE
· GOTO start
ENDIF
LOOP
it looks like i2cin/out is for stamp to i2c chip, NOT stamp to stamp.
