BS1 question
Ok,
· Its been a year since I wrote any code, and I need some help stat!!!!!
· I want to make a BS1· run several lines of code then pause for 20 mins and run again, to no end.
· How?
Noli nothis permittere te terere
· How?
There has to be a better way , right?
If you PAUSE 60000·20 1200 20 times, that'll be 20min.
[noparse][[/noparse]"Hot pin"? What's that all about?· No, wait, DON'T tell me.]
Post Edit -- 1200 times
Where've you been, anyway?
Further Post Edit -- No, it's 20!· Let's see, 60000ms = 60sec = 1min.· So, minutes it should be, for 20 minutos the minutes VAR should be 19 (0 - 19 = 20X.)··Got the Verizon-Math guy's voice ringing in my head here.· Don't know why I panicked and multipled by 60 like that.· Terrible.· Sixty thousand milliseconds, dekaminutes, it's all too much.
Post Edited (PJ Allen) : 3/8/2009 2:34:39 PM GMT
· Well lets see,
· I am taking a BS1, ( b/c its the only chip that I have assembled currently) and making a trigger for a digital camera that is going upstairs in his house. I will have it take one pic every 60 seconds for the first few days.
Once I establish a likely pattern from 1440 pics a day, I will concentrate the shutter action for the peak times. Taking as many as 15 pics a minute.
Oh and the friends house has rear access that is secluded and so therefore I can access the camera without compromising my mission, so I can download it everyday.
Post Edited By Moderator (Dave Andreae (Parallax)) : 3/10/2009 10:09:27 PM GMT
are you a UFO hunter or coastguard?
Nobody trying to wear you down here...
Mike2545
This message sent to you on 100% recycled electrons.
Post Edited (Mike2545) : 3/8/2009 5:38:56 AM GMT
(Former DCE/SP R.A.I.D. Crewchief)
Try this:
' {$STAMP BS1} ' {$PBASIC 1.0} SYMBOL minutes = B1 ' number of minutes OUTPUT 0 'Makes Pin 7 an Output pin the "hot" pin START: 'Loop label HIGH 0 'Set Pin 7 to HIGH, and take a photo PAUSE 700 'Wait for 0.7 seconds just to be sure the camera button is pressed long enough LOW 0 'Set Pin 7 to LOW FOR minutes = 1 to 20 ' 20X PAUSE 60000 ' 1 minute NEXT GOTO START 'loop from Start END 'Not really necessary since the program will never leave the loopPost Edited (luisr320) : 3/19/2009 2:34:47 AM GMT
here -- http://forums.parallax.com/showthread.php?p=790507
