Batteries not included
I just got my Propeller starter kit and had was gleaming with joy as I read through the brochures and opened the box.
I couldn't wait to get this thing hooked up to my PC and start spinning.
Wait, it has a USB cable and a power plug but no power supply NOOOO!!!
Batteries not included [noparse]:([/noparse]
As I live in Iceland I can expect to wait for another 2-4 weeks to start using my starter kit.
Until then I'll just have to read the book and dream of the applications I'm gonna write with my propeller chip.
This is a reminder to RTFM.
But for the beginning it should be possible to run the board without batteries or power supply. There should be a voltage regulator available, as the propeller itself runs with 3,3V but the power supply to be attached is a 7,5V type. So it should be possible to connect the power supply connector (or the voltage regulator) with the 5V comeing from the USB-Port. Good enough to light some LEDs. But don't attach to much other devices as a USB port can only drive 500mA.
I used so many 'shoulds' because I don't have a Starter Kit. I simply ordered the chip and put it on a breadboard.·I bought a USB to USART converter and a 3.3V dropdown regulator and I use the USB power to run the Prop. Works fine!
Have fun with your prop.
Post Edited (MagIO2) : 3/17/2009 10:15:39 PM GMT
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
You must have a spare wall wart somewhere. If not go to your nearest hotel and scrounge one from the box of adapters guests have left behind. Most hotels are full of them.
Thanks for the info.
I'm completely new to electronics on this level and am just a programmer interested in the hardware part of my work.
I don't even have a clear understanding of the difference between amps and volts [noparse]:)[/noparse] so hauling a car battery into my living room or coiling batteries sound like insurmountable obstacles to me.
As I understand it I should be able to plug this into the usb port of my PC and turn it on?
The box says they recommend a 7.5 v 1amp power supply and that I don't have.
I'm too nervous of taking some power adapter that has different voltage or amp measurements and plugging it into my new board.
I'd hate to ruin the board before I even turn it on [noparse]:)[/noparse].
The surprising thing is that my invoice says that the package includes a power supply.
Lastly, yes I bought my started kit straight from Parallax (using this site) and I just didn't notice the text saying (adapter sold separately).
I'll try the USB port when I get home (I don't have anything to plug into it so that shouldn't be a problem) I just want to start programming this thing [noparse]:)[/noparse]
nisbus
E=I*R
E=Voltage
I=Current
R=Resistance
Higher voltage and current are ok as long as within tolerances of the voltage regulator(7805 if I am not mistaken http://www.fairchildsemi.com/ds/LM/LM7805.pdf)
No problem to lay it safe though.
In germany we have U for the voltage.
And in germany the current is drawn by the circuit that's attached to the power supply. So, if the circuit only needs 5V 100mA then it only draws 100mA even if the power supply could source 1A ;o)
That's why in fact the current statement on the power supply can be lots higher. The voltage can be higher in a certain range which is given by the voltage regulator used.
Can't someone make a photo of the Starter Kit and mark the pins that he has to connect (+5V from USB with the voltage regulator U in pin?). I don't have this board otherwise I'd do it myself. Don't you see that this poor guy is suffering?
v for volts
look carefully at the raised print or label on the power supply. If it has voltage
output of anything between 6v-9v DC (the graphic used to indicate DC looks like this:
Then look for the "center positive graphic. It looks like the picture attached.
If you've got these covered with another adapter, and it fits you are in business.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 3/18/2009 6:07:07 PM GMT
Since you do not know much about electronics, go to your local electronics store and ask for a wall wart, plug pack or whatever you call them in Iceland. They are just power adapters that plug into the wall power socket and run small electronic devices such as phones, etc. Ask for a 6-9V power pack with 200mA to 1A centre positive with a 2.1mm connector. Take the board with you so you can check the connector fits.
You can use batteries but since you don't know anything about electronics give this a miss for now. You probably do not have a soldering iron to connect the plug anyway.
This should get you started and read OldBitCollectors book and the Propeller Manual. Anything you don't understand, just ask. Mostly you get great advice on this thread.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
Post Edited (Cluso99) : 3/18/2009 3:46:25 PM GMT
Now I just need to read the manual and start coding.
nisbus
