This controller does not need any extra command to initiate or terminate the data transfer. As long as the touch pad detects touches, controller will continues to send 5 byte data packet to Propeller. Sc400 data sheet has all the command you can sent to the controller, But I have not use those in my codes. I have attached both files again.
This is my first Propeller project. Any suggestions for improvement are welcome.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=BER273-ND
Both the touch pad and the controller cost was around US$80. Only used controller pin 2 Tx and 3 Rx and connected these two pin to Propeller. Use touchpad.spin and touch_test.spin. touch_test.spin will display the X and Y coordinate of the touch point on the TV. The values generally between 1K to 16K.
Post Edited (Guruge) : 3/18/2009 4:29:26 AM GMT
www.tdswieter.com
