Servos on Battery project...How much current do they pull?
I am working on a project that is battery powered and requires 2 servos.· I have looked at many servo dealers spec sheets, and I am not able to find how much current they draw under user conditions.
I am 100% certain that people here have dealt with this and I was wondering if I could get some advice.
-If I have 2 of Parallax's full-rotation servo motors and a 2lb load on them...and they are in constant rotation for 3-4 hours...What size of battery should I expect to use?·· 500mAh? 1Ah?· 5Ah?· 10Ah?
-I looks like servos are rated to 6V.· Should I attach them straight to a 6V battery, or can I power them off of my existing 5V 1A voltage regulator(s)?
Any help would be greatly appreciated.
Shaun
Post Edited (Steel) : 3/17/2009 5:32:34 PM GMT
Shaun
To calculate the battery capacity add the two current readings together, multiply that by the number of hours they will run, double that to allow for aging of the batteries and you have a ballpark amp/hour rating for the battery.
I'd use a 5Ah battery, maybe a 10Ah battery. 2 pounds is a moderate load, so figure 0.25A to 0.5A. Two servos makes 0.5A to 1A. For 4-5h, that's a 5Ah battery. As kwinn suggested, measure the current under load if you want accurate estimates of battery life.
It's impossible to determine the load when it is stated as two pounds, because servos (like other rotating machines) are loaded in terms of moment (torque), not force or weight.
You could, for example, determine the required torque, then calculate the work done per unit time (in horsepower or in ergs/second or in watts or in any other power unit), then assume, say, 50% efficiency in the servo, finally converting if necessary to come up with the required power in watts.· Double that because you don't want to run batteries down more than 50%.· Divide by 6 for the 6-volt supply, and -- voila! -- that's the current.· Multiply by the time you need from the batteries, and that's the AH rating you need.
But you can't start with just "pounds".
· -- Carl, nn5i@arrl.net
I sure wish servo providers would provide a torque/current table to show the performance of the servos...but I guess that is just not something that I am in control of.
