ENC28J60 Recommendation — Parallax Forums
Farmer ScottFarmer Scott Posts: 30
edited 2009-03-17 19:21 in Propeller 1
Hey folks...
My apologies if this discussion has already been beat to death, but I'm wondering if someone can recommend an ENC28J60 module that would work good with the existing objects?
I see quite a few of them with varying price ranges, and am not sure which one would be best.· This module would be for completing development of a DNS resolver...future ones will likely be built completely onboard the appliance I'm working on...
I'd prefer a module (or at least kit with all components and PCB included) so I can finish up my code as quickly as possible.
Scott
  • LeonLeon Posts: 7,620
    edited 2009-03-16 15:13
    I've got one of the Olimex ones but haven't tried it yet. It's got a 10 pin DIL header, so is very easy to mount in a circuit.
    They are available from Sparkfun.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • trodosstrodoss Posts: 577
    edited 2009-03-16 16:14
    The uController PropNIC Ethernet adapter card (uses the ENC28J60) is also an option, if you don't mind doing a little assembly yourself:
    http://ucontroller.com/documentation/PropNICDoc.html
    You might have already seen the PropTCP project, however just in case I thought I woud mention it:
    http://code.google.com/p/proptcp/
    [noparse][[/noparse]Edit:] The above mentioned PropNIC is designed to work with the PropTCP code.
    I have seen a few other (some of them Arduino shields) that use the ENC28J60.·
    I ran across this Modtronix module as well:
    http://www.modtronix.com/product_info.php?products_id=319
    Post Edited (trodoss) : 3/16/2009 4:24:05 PM GMT
  • parts-man73parts-man73 Posts: 830
    edited 2009-03-16 18:37
    trodoss said...
    I inserted a note on my website, but it's on the policies page and it's possibly overlooked.
    I will solder and test any kits before shipping for a modest charge. So never let lack of soldering skills or equipment stop you from trying any of my kits.
    I see quite a few of these ENC28J60 modules available now. Most are preassembled surface mount with a small footprint compared to the PropNIC. I don't want to take this thread too far off topic, but would you all prefer a preassembled PropNIC, something small, or you you prefer in it's current form? I recently purchased equipment for assembling SMT PCBs, so this is now a possibility.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • Nick McClickNick McClick Posts: 1,003
    edited 2009-03-17 17:12
    Personally, I prefer putting it together myself, and the build is pretty darn quick. I'm wonder what others think about it, though.
    There's also an ENC 28J60 libary in the object exchange
    Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
    edited 2009-03-17 17:20
    uController's NIC is a very straightforward, quick build..
    (I've built a couple of them!)
    It's nice of Brian to offer to assemble them. No barriers to entry!
    OBC
    New to the Propeller?
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card connected? - PropDOS
    edited 2009-03-17 18:03
    As OBC said, definately great that he offers to pre-assemble them.
    I can vouch for the build quality of the pre-assembled pieces (see attached).
    I was lucky enough to get one of the first batch (pre-assembled) SD·interface cards from uController/parts-man73.· I would bet that if you ordered one if the NIC cards and had it assembled you would get the same kind of quality.· I need to order one of the NIC cards myself actually (I haven't yet).
    956 x 584 - 61K
    edited 2009-03-17 18:40
    The SD card adapters are always preassembled and tested (OBC - they are tested with PropDOS) Because the SD socket is surface mount.
    I just ordered a batch of the SD card adapters that is redesigned using all surface mount components (except the headers) now that I have SMT soldering equipment and stencils, I should be able to spend less time soldering, and more time making new designs.
    Thanks for the input guys! It looks like the general consensus is to leave the PropNIC as is, so be it.
    Brian
    Post Edited (parts-man73) : 3/17/2009 6:58:42 PM GMT
    edited 2009-03-17 19:07
    Update: Just ordered one myself [noparse];)[/noparse]
    great, ty!
    Brian
