4-wire SPI Interface — Parallax Forums
RogerInHawaiiRogerInHawaii Posts: 87
edited 2009-03-17 22:40 in Propeller 1
I have a device that uses a 4-wire SPI Interface. I'd like to be able to communicate with this device using the Propeller chip. Is there any object that is already written that can do this? I looked through the object list under the section titled "Protocol: SPI, 1-wire, 12C, asynchronous serial..." and although it mentions SPI in the title I wasn't able to find any objects that actually provide any SPI interface communications. Is one available?
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-03-17 01:57
    What is your device?
  • RogerInHawaiiRogerInHawaii Posts: 87
    edited 2009-03-17 02:01
    The Acam TDC-GP2
    edited 2009-03-17 02:10
    50pS resolution? Are you kidding me? I didn't even know time itself was quantized that low! That's just craziness!
    As for the setup, I'm actually learning SPI, myself. I know the Propeller CAN do it - how is another story.
    edited 2009-03-17 02:14
    Yes, I would think that if the Propeller can handle other communications standards it ought to be able to handle the 4-wire SPI. But I don't want to have to write it myself. I don't think I COULD write it myself. I just need a nice, existing, object that will let me do the little bit of communications I need to do with my TDC-GP2.
    So, anyone know where I can get an object to handle that protocol?
    edited 2009-03-17 03:04
    I don't think there is a specific object for SPI. From what I know and used SPI is more general term than say I2C. SPI data packets and such vary and as you also may know there is three wire and four wire. A generic driver or routines can probably be created as an example, but I don't know that it would every be a good stand alone object.
    I bet you could write simple SPI send/receive for your device in SPIN. Try it. We will watch and help.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
  • telluriantellurian Posts: 52
    edited 2009-03-17 03:08
    SPI is simple enough ... 4 wires: data in, data out, a device select line, and a serial clock line. It is basically a high level hardware interface specification. After that things diverge. Every device has its own specific protocol in terms of timing, command structure, data bit width (8, 11, 12 etc). So you will not find and one "standard" SPI interface. It does not define a communication protocol as well like I2C or RS232, but a hardware interface. One alwaysHAS to look at the specific device's datasheets to figure out timing and I/O bit structure. There is a lot of commonality but not any single SPI interface. The best bet is to look at some of the simple interfaces (cause yours is relatively simple) for some of the SPI ADC's in OBEX (i.e. ADC0834) and try to convert that to your device. But you will still have to use the data sheets to determine correct timing and I/O bit structure.
    A bit of work the first time, but once you do one the next one is easier by far. The propeller can easily handle your device (took a quick peek at the data sheet).
    Not the answer you were hoping for I know, but that is SPI.
    -tellurian
    edited 2009-03-17 03:27
    See here: http://forums.parallax.com/showthread.php?p=792520
    www.tdswieter.com
    edited 2009-03-17 04:57
    Another alternative to taking on the learning curve, is to offer up a few of these devices to anyone who wants to code an object for it. It may seem lazy at first, but in my opinion, it's a fair trade - you get the software from someone, and they get some free hardware. That's how I got a driver written for an ADC I was eyeballing, and an accelerometer I bought. Another plus, is it adds yet another object to the Propeller OBEX library that everyone can use, further making the propeller more capable.
  • BillDerBillDer Posts: 33
    edited 2009-03-17 09:59
    Hi, I had the same problem. What I did is use the BS2 object and the shiftin/shiftout subroutines. It seems to work, though I am not quite done with this yet. Here is the code snipets I used. Hope it helps. This code compiles, however it is not fully debugged yet. However, it does communicate (sends and receives) data from the accelerometer.
    Con
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    cs = 2
    clk = 1
    reset = 0
    Dout = 3
    Din = 4
    var
    byte v ,r,v2,v3
    word reg, data, receive,what
    obj
    bs2 : "BS2_Functions"
    Pub Start
    'dira[noparse][[/noparse]cs]~ set pin to input
    dira[noparse][[/noparse]cs]~~ 'set chip select to out
    dira[noparse][[/noparse]clk]~~ 'set chip select to out
    dira[noparse][[/noparse]dout]~ 'set dout to input
    dira[noparse][[/noparse]Din]~~ 'SET to din output
    BS2.Start(31,30)
    BS2.Debug_Str(string("Begining Program",13))
    repeat
    BS2.Debug_Str(string("enter register address then hit enter : ",13)) 'get the register address to query from the user
    data := BS2.DEBUGIN_DEC 'get address to send to accel.
    'now construct message to send to accelerometer
    data := data << 8 'shift the address to the correct byte before sending
    write_accel(data)
    display(data,1) ' 1= sending data
    waitcnt(clkfreq/10 + cnt)
    receive := read_accel(data)
    display(receive,2)
    convert_2_g(recieve,2) 'for now just do 2's complement data
    pub write_accel(send_data)
    outa[noparse][[/noparse]cs]~~ 'set pin to high
    outa[noparse][[/noparse]cs]~ 'set pin to low
    outa[noparse][[/noparse]clk]~ 'set clk to low
    bs2.pulsout_uS(clk, 210)
    bs2.shiftout(Din, CLK, send_data, BS2#MSBFIRST,16) 'most significant bits first
    pub read_accel(send_data) : results
    outa[noparse][[/noparse]clk]~ 'set clk to loW
    results := bs2.shiftin(Dout, clk, BS2#MSBpost,16) 'most significant bits first
    {{ PUB SHIFTIN (Dpin, Cpin, Mode, Bits) : Value | InBit
    Shift data in, master clock, for mode use BS2#MSBPRE, #MSBPOST, #LSBPRE, #LSBPOST
    Clock rate is ~16Kbps. Use at 80MHz only is recommended.
    X := BS2.SHIFTIN(5,6,BS2#MSBPOST,8)
    PUB PULSOUT_uS(Pin,Duration) | ClkCycles
    Produces an opposite pulse on the pin for the duration in 1uS increments
    Smallest value is 10 at clkfreq = 80Mhz
    Largest value is around 50 seconds at 80Mhz.
    BS2.Pulsout_uS(500) ' 0.5 mS pulse
    PUB SHIFTOUT (Dpin, Cpin, Value, Mode, Bits)| bitNum
    Shift data out, master clock, for mode use ObjName#LSBFIRST, #MSBFIRST
    BS2.SHIFTOUT(5,6,"B",BS2#LSBFIRST,8)
    pub display(value,in_out)
    If in_out == 1
    bs2.debug_str(string("sending : "))
    bs2.debug_bin(value,16)
    elseif in_out == 2
    bs2.debug_str(string("receiving bin : "))
    bs2.debug_str(string("receiving dec : "))
    bs2.debug_str(string("dec : "))
    bs2.debug_dec(value)
    else
    bs2.debug_str(string("receiving new data : "))
    bs2.debug_str(string("receiving alarm : "))
  • Tom CTom C Posts: 461
    edited 2009-03-17 11:34
    Hi all,
    Attached is an I2C object written by Joe Lucia: http://irobotcreate.googlepages.com/home
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
  • Ken PetersonKen Peterson Posts: 806
    edited 2009-03-17 16:26
    This seems like a popular request lately. I would think an SPI object, especially a master, should be easy to do. It's synchronous communication, so timing precision isn't critical. It basically implements a shift register in software, with a couple of options for phase and polarity. I'm surprised there's no GP SPI object in the OBEX.
    If I find myself needing SPI for anything in the near future, I'll write it as a GP object and publish it.
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
    Again, read this thread - Parallax is working on a general purpose SPI: http://forums.parallax.com/showthread.php?p=792656 with two different flavors. Should be ready this week.
    www.tdswieter.com
