Just a Thought...
I am wondering if it would be worth it to try this: If·I stuck a vga driver and a·keyboard driver together, made it so it saved the input onto a flashdrive, and on command loaded it into·a cog, using another cog to interpret it, could·I program and run programs from the propeller itself? -- Just a Thought...
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
So besides writing an editor which allows comfortable source-file editing you would have to write your own compiler which runs on the propeller.
I would like to have the development-environment on a prop too, but that'll be a lot of work.
MagIO2: That is no longer true. We only require a propeller compiler. We have PropDOS, an editor, VT100 terminal emulator, memory (SRAM and SD/microSD), etc. It is just putting this all together and we will have a full Propeller SBC (Single Board Computer) - see my recent thread on the Propeller SBC using my TriBladeProp - it is functional and I am putting the pieces of code together now. As I said, the only piece missing is the Prop based compiler.
Heater is working on a Z80 emulator with CP/M which is pretty much working and we are now ready to add that to the TriBladeProp which has cheap 1MByte SRAM and microSD socket. This will give us the full 64KB RAM/ROM plus some RAM disk and huge microSD hard disk emulation and CP/M. There are other "retro-computer" emulations on the horizon also.
So, stay tuned...
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
For the record, PropDOS borrowed heavily from FemtoBASIC for it's abilities to
interact with the SD and spin up binary files.
We lack a multipass propeller-based spin compiler, however it is possible now
create BASIC programs in Femto and even drop into a full-screen editor
to edit them. Wouldn't take much to combine the two programs. [noparse]:)[/noparse]
Yes, a lot has been done by many, but there is more to do.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Having a PropDev-Board with a head mounted display would truely be good for my daily train-trip to work ;o)
