GPS & Javelin
Hi all you Javelin enthusiasts!
I am trying to communicate with the parallax GPS module.
I have had success communicating with it using the /raw stream, but am getting interesting results when I use SMART mode.
In STAMP one would send ("!GPS", $01) to the GPS receiver and expect a single byte answer.
In Javelin, I am sending;
GPS_tx_Uart.sendString("!GPS");
GPS_tx_Uart.sendByte(0x01);
CPU.delay (5000);
if(GPS_rx_Uart.byteAvailable())
valid = GPS_rx_Uart.receiveByte();
System.out.println(valid );
When this snippet loops, I get the following output;
1 33 71 80 83 1 33 71 80 83 1 33 71
when I should be expecting;
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
Any ideas? Suggestions??
Istha
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
CPU.delay (5000);
Istha
Adam Smith
Sorry, no test program as I never had a GPS to test it.
You are supposed to call a·method and then directly
use the declared public variables (as read-only values)
that will be set with results by the method.
The class should be saved in folder ...\lib\stamp\peripheral\gps
Could ypu post your raw mode code?
My class only supports smartmode.
regards peter
Post Edited (Peter Verkaik) : 3/13/2009 8:30:15 AM GMT
Thank's for the library.
Here's the code that reads the RAW data. It works, but of course you ahve to do all the parsing to get to the numbers.
Istha
static void ReadGPSMessage()
c = 0xff;
while (c != '\n')
c = (char)GPS_rx_Uart.receiveByte();
GPSBuffer.append(c);
} //end if
} // end while
} // end bufferMessage
Adam Smith
Here is the "raw" output;
$GPRMC,020247,A,2731.6377,S,15255.1461,E,000.0,354.0,160309,,,A*67
$GPGGA,020248,2731.6291,S,15255.1458,E,1,03,06.6,00087.3,M,039.4,M,,*57
$GPGSA,A,2,07,17,25,,,,,,,,,,06.7,06.6,00.9*0D
$GPGSV,3,1,12,04,06,001,00,07,33,067,42,08,63,110,36,10,01,291,00*79
$GPGSV,3,2,12,11,26,106,00,13,01,018,00,15,22,229,00,17,68,338,35*79
$GPGSV,3,3,12,25,15,055,38,26,29,229,00,27,37,215,00,28,56,183,28*7A
$GPRMC,020248,A,2731.6291,S,15255.1458,E,001.7,354.0,160309,,,A*6D
$GPGGA,020249,2731.6290,S,15255.1459,E,1,03,06.6,00087.3,M,039.4,M,,27*75
$GPRMC,020249,A,2731.6290,S,15255.1459,E,001.7,354.0,160309,,,A*6C
$GPGGA,020250,2731.6290,S,15255.1460,E,1,03,06.6,00087.3,M,039.4,M,,*54
$GPGSA,A,2,07,17,25,,,,,,,,,,06.7,06.6,01.0*05
$GPGSV,3,1,12,04,06,001,00,07,33,067,42,08,63,110,35,10,01,291,00*7A
$GPGSV,3,2,12,11,26,106,27,13,01,018,00,15,22,229,28,17,68,338,34*77
$GPGSV,3,3,12,25,15,055,38,26,29,229,29,27,37,215,00,28,56,183,27*7E
$GPRMC,020250,A,2731.6290,S,15255.1460,E,001.7,354.0,160309,,,A*6E
$GPGGA,020251,2731.6290,S,15255.1461,E,1,03,06.6,00087.3,M,039.4,M,,*54
Adam Smith
I have tried you library and could not get it to work.
I have even taken a section out of teh code and put it directly into my program.
I have had a look at the code in your library.
It's beautifully written as could be expected, however I have a concern with this section;
" while (i<response) {
buf[noparse][[/noparse]i++] = (char)rx.receiveByte();
Given that the definition of .receiveByte() says;
"Receives a byte from a receive Uart. This method will block until a byte is available.
Returns:
the next byte in the receive buffer."
This suggests that if ther eis no data in the buffer the program will loop indefinitely and lock up.
Is this the case?
Istha
Adam Smith
I have tried to use your library, but am having greta difficulty getting it to link.
I KNOW the code is in teh right library.
Here is my code;
import stamp.core.*;
import stamp.peripheral.gps.GPS_Parallax;
public class GPSLog_4
//GPS Variables
final static int GPS_SERIAL_RX_PIN = CPU.pin1; // Transmit Pin
static Uart GPS_Uart = new Uart( Uart.dirReceive, GPS_SERIAL_RX_PIN,
Uart.dontInvert, Uart.speed4800,Uart.stop1 );
static int Satellites;
public static void main()
GPS_Parallax(GPS_Uart,0);
System.out.println("Starting\n\r" );
CPU.delay (20000); //Allow time for the system to settle
while (true)
Satellites = getSats() ;
System.out.println(Satellites );
} //End while
} // end main
When I compile, it throws errors on;
GPS_Parallax(GPS_Uart,0); - The keyword new is expected........
Satellites = getSats() ; - no method named getStats.....
This would indicate it can't find teh library.
I have tried;
import stamp.peripheral.gps.*;
and
import stamp.peripheral.gps.GPS;
Still can't find the library.
Any advice?
Adam Smith
· //GPS Variables
· final static int GPS_SERIAL_RX_PIN = CPU.pin1; // Transmit Pin
· static Uart GPS_Uart = new Uart( Uart.dirReceive, GPS_SERIAL_RX_PIN, Uart.dontInvert,Uart.speed4800,Uart.stop1 );
· static int Satellites;
· static GPS_Parallax myGps = new GPS_Parallax(GPS_Uart,0);
· public static void main()
··· System.out.println("Starting\n\r" );
··· CPU.delay (20000); //Allow time for the system to settle
··· while (true)
····· Satellites = myGps.getSats() ;
····· System.out.println(Satellites );
··· } //End while
· } // end main
BTW, Thanks for the raw data.
regards peter.
receives exactly as much bytes as the GPS will transmit
depending on which command· was sent to the GPS.
If the GPS operates correctly (eg, no malfunction)
this loop will not block.
regards peter
I have it working now (or should I say; you have it working!).
I am suprised at the slow response with the "smart mode" calls. i.e., if you do this;
myGps.getTime();
Satellites = myGps.getSats();
HRS = myGps.hours;
MINS = myGps.minutes;
SECS = myGps.seconds;
it takes around 2 seconds for the GPS to send the data back.
In Raw mode, you can get the stream, parse the data and convert the variables in about half a second.
I would have thought that by putting a micro on the GPS, you would have been able to get the data out faster.
Thank's anyway for your help. At least I have been able to test the 'smart" mode.
regards,
Istha
Adam Smith
