Quadrature Encoder Object question... — Parallax Forums
Chris_DChris_D Posts: 305
edited 2009-03-21 12:45 in Propeller 1
Hi guys,
I have a question about the quadrature encoder object I am hoping someone can answer.· I would like to know if there is a way to reset the counters to zero?· I thought I could just set the variable to zero but that didn't seem to work out very well.· Apparently the object somehow prevents this from happening.
Chris
  • telluriantellurian Posts: 52
    edited 2009-03-15 23:11
    I remember doing something like that a while back. I had to add a method tho the encoder object. Try this method:
    PUB Clear
    'clears all of the encoder values (i.e. a reset)
      longfill(Pos, 0, TotEnc+TotDelta)
    -tellurian
  • T ChapT Chap Posts: 4,260
    edited 2009-03-16 01:32
    Just stop and start the cog, that's what I ended up with.
  • Chris_DChris_D Posts: 305
    edited 2009-03-16 10:36
    Yeah, I know I can start and stop it, but I was hoping for a way to clear just a specific variable.· Tellurian, I will give your method a shot and see if I can manipulate that into doing exactly what I want.
    Thanks guys!
    Chris
  • Richard S.Richard S. Posts: 70
    edited 2009-03-19 16:07
    See· http://forums.parallax.com/showthread.php?p=720621I have done what you are asking about, resetting an individual axis while preserving the other values.
    Richard in Michigan
    edited 2009-03-19 22:21
    Richard,
    Thanks very much for the link - I have downloaded your code and will certainly incorporate this feature!!!
    Chris
  • Jeff MartinJeff Martin Posts: 762
    Gentleman,
    You should not need to reset the counter, and in fact if one were to achive resetting it outside the·cog that is reading the encoder(s), you'd be possibly creating a slight error (if the counter changed at a critical time in the read/write sequence of the encoder cog).
    For this reason, the Quadrature Encoder cog does not allow resetting the counter and, instead, provides a much more useful feature... Delta tracking.
    Simply call ReadDelta() every time you want to know how much the encoder has moved since the last time you "looked"... it provides a signed value, so if it moved backwards, you'd get a negative number.· If it hasn't moved since the last time you called ReadDelta(), then it returns 0.
    Read item 4 of "To use this object:" at the bottom of the code.
    --Jeff Martin
    · Sr. Software Engineer
    · Parallax, Inc.
