HPS?
                    Hi,
I'm new to this sensor scene and I am wondering if I could use the Parallax GPS module with my own transmitters (i.e. from within my home instead of from space )
I'm looking to build a Home Positioning System that has the accuracy of millimeters. Is this something that is possible?
If not the GPS module, then could I use ultrasound ?
What is the range of ultrasonic sensors/transmitters?
Any ideas would be appreciated.
nisbus
nisbus
Ultrasound wouldn't work well because it would bounce off the walls quite easily, leading to bad readings.
Your best bet would be to use IR beacons and triangulate your position, rather than measure flight time.
Do you know of any suitable hardware for creating IR beacons?
I would need to be able to track 10 objects in real time so I guess I would be needing 30 beacons all sending out different frequencies?
Thanks again,
nisbus
1) transmit beacon number via RF
2) transmit 'start' via RF
3) swing a IR LED around 360 at constant speed.
The receivers can then calculate their heading from a single beacon, and relative position if you have two or more beacons. The system almost certainly won't give you mm of accuracy, but it should work to within a foot or so, more if you're very precise in your implementation. One side note about this implementation is that at the base level you can probably only get about 1/2Hz of position update. If you optimize the system, there isn't any real upper bound besides processor speed.
For the hardware part, any suitable IR LED and IR receiver should work. Most of the structure and all of the software will have to be custom built, but that's part of going where no man has gone before.[noparse]:)[/noparse] I'm going to try the system with 56 kHz so that it won't interfere with the lower frequency IR distance detectors on robots.
As for the number of beacons, you only need a constant number that will provide complete coverage. Each object that you want to track will obviously require it's own receiver of IR and RF signals.
I live in an apartment building and my PC picks up at least 10 routers and usually those stay in the same place.
I don't know how I would plug that into my Propeller starter kit (or if it's even possible) but that would only require me to have a wifi receiver and not needing to put up beacons.
kwinn's suggestion sounds more in the line of how GPS actually works so that might be a good solution.
My only concern is the range of IR (across rooms etc).
I've never heard of the xbee module but I'll look into that.
nisbus
IR will work across a room just fine with regular modules (your remote works from across the room, right?), and you can always get higher powered LEDs if need be. Mouser has some that are rated for communication to 60 feet or so outdoors.
Kwinn's suggestion would work, you just need one more beacon to find your position. It's a tradeoff between beacon count and beacon complexity, and up to you. Another idea you may want to consider ( and that might get you really close to your accuracy requirement) is to use a set of fixed position locations that your device periodically returns to or passes over (question: is this a mobile robot system or something else?). When the device hits that position, it knows exactly where it is at that moment in time. You can then use a accelerometer and gyroscope to calculate your position once you move away.
What I'm trying to achieve is getting the position of my hands (or even better, each finger) in 3D space so I can send that to my 3D interface on a PC.
If we start with just 2 objects (hands) where they are stationary and press a button (space reset) it would probably be possible to measure their position according to the change in the accelerometer and gyroscope based on the original "zero" point?
nisbus
http://www.ted.com/index.php/talks/pattie_maes_demos_the_sixth_sense.html
The problem with accelerometer and gyro combo is that you need one for each finger...
It would be possible to just track the hands position using an accelerometer and then track the fingers in relation to the hand.
That would also allow for a more accurate finger reading.
I've ordered one tri-axis accelerometer for testing and I'll keep you posted on my results.
nisbus
nisbus
http://www.sparkfun.com/commerce/categories.php?c=85
