What do I need?
We Skratch King Productions is trying to bulid our own UAV and we our looking at your basic stamp Microcontrollers to make a RC plane have an AutoPilot but I am asking to make sure of what i need or etc... We all ready have a GPS Recver so And Im looking at the board with the 4 R/C Servo Connection ports but its the Board of Eduction. But The problume that Im seeing is that how can I beable to making were it can download flight plane's wirelessly as its in the air and with out having to trun the board off or resting it or is it possable or would i have to go out and buy the boards that are made for that kind of stuff thanks Justin m Romaine
- Stephen
You would not download anything other than a few parameters for the autopilot like a new heading, new altitude, and rate of change or time to new settings. You could use a multichannel R/C link to supply that sort of information or you could use any of several types of data transceivers. A lot depends on your range requirements and power budget. Since R/C aircraft control is really line-of-sight, it doesn't take much power. A 900MHz xBee Pro transceiver (www.digi.com/products/wireless/point-multipoint/xbee-pro-900.jsp) would work fine up to a couple of miles. This would also be able to transmit diagnostic data back to you on the ground.
Post Edited (Mike Green) : 3/14/2009 5:07:30 PM GMT
I still think the Control Board is too large and heavy, but it's your call. When I get around to building an auto pilot, I'll be using the prop-stick on a custom PCB that will also hold stuff like accelerometer, gyro, gps, RF, etc.
The carrier board you can make in something like eagle (and use something like BatchPCB.com) or expressPCB. If you use BatchPCB they can cut it to any shape that you want. Either way, you can customize which sensors you want and mounting hole positions and the like. For prototyping (in flight) you can use a soldered breadboard like the kind radioshack or GadgetGangster.com sells. BTW, GG will be getting some nice prop boards in at the end of the month, you may want to try them out.
Don't worry about 'idea theft', at least from me. I haven't even begun on my UAV project yet, and probably won't get a start until the summer when school lets out...
The advantage of a smaller (and lighter) board is that you can have a lighter plane, leading to longer flight times or a bigger payload.
