Interfacing with a Gameboy?
Hey all,
Has anyone tried interfacing with the original Gameboy from so long ago?
I recently found the cartridge pin layout and when I get around to ordering a Proto Board (next pay check) I intend to hook it up and see what can be done, I am thinking to either write a LCD display driver for the prop or build a MIDI controller.
Anyway, Thoughts/Ideas?
Parallax Forums - If you're ready to learn, we're ready to help.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
EDIT:
here is the pin layout that I could find, I am sure there is a better version somewhere
the gameboy cartridge apparently has a 5V line but I am not sure if that is the same for the pocket version, it may be 3.3v
http://pinouts.ru/Game/CartridgeGameBoy_pinout.shtml
Post Edited (James Alexander Shield) : 3/14/2009 2:50:12 PM GMT
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
A better choice IMO would be looking at doing something with the Dreamcast VMU, of which I also have a few for the same reasons and, again, have done nothing more with. They are equally programmable, and seem more readily available than GB's which I expect have largely gone to landfill ...
www.svas.com/computers/Dreamcast_VMU_TN.png
Have you considered getting hold of an older Palm Pilot with a serial interface, and install a Basic interpreter or something, to build your interface with?
Don't visit my new website...
I also suspect that CP/M maybe portable as well, I will have to experiment along the way.
http://www.bripro.com/low/hardware/index.php?page=devboy
It uses the link cable to communicate/program a GB (also has PC-side software included).· If you have/find a "Bung" cartridge, build your own (see: http://www.devrs.com/gb/hardware.php), or do the mod that Brian did, you could most likely program the gameboy directly.· I mention it because it sounds like what you are interested in doing.
Game Boy Developer's Kit (GDBK) is·good for programming on th GB in general.· I have made a few things with it a few years ago.
http://gbdk.sourceforge.net/
Emulating the·original Game Boy's processor (LR35902) on the Propeller (using ZiCog as a reference) might be a fun project on its own.·
I seem to see quite a few of them around at garage sales, PC gaming stores and eBay.
It's quite well documented and being self-contained is what appealed to me over the GB ( the mere mention of EEPROM with no I2C/SPI prefix is enough to put me off these days ). Re-looking at the GB display driver circuit, it might be possible to bit-bang that from a Prop.
I did download some pre-written demos to a VMU but never wrote my own code. With the VMU in controller attached to Dreamcast running its browser via its dial-up modem plus a dial-in server configured to deliver the required file it's an easy(ish) download process. Had it working through a local PABX and and my Win98 PC. It is apparently possible to bit-bang code in directly but never tried that.
One starting point would be : www.maushammer.com/vmu.html
