Recommended Prop Schooling
· I'm new to the Propeller.· I've been using the Stamp2 for one year now and my only programming experience is QBasic and PBasic.· The Prop is a whole new programming concept for me.· I have been considering taking an educational course in some·related programming language.· Can you recommend a programming language that most closely resembles Spin?· Even better does anyone know of any colleges or universities that use Spin in their microcontroller cirriculums?· I reside in the Southern California area.· Thank-you.·
If you have some experience with QBasic and PBasic, you should not find problems with the Spin language.
The only thing that will be totally new to you, will be the structure of Spin programming, with 8 Cogs.
My experience is that the propeller manual explains this just fine, so have a look at that one.
Kind regards,
Robotfreak
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I am aware that there are a lot of Propeller resources currently out there and more being added each day. What I would like to see is a “Weekend Propeller Project” that might give complete details (Commented Code and Detailed Schematics) on how to connect a PING sensor and a Serial LCD module to the PEK or Proto board and have the PING distance displayed on the LCD. This would give me a practical example of how to use two different objects with the Propeller.
My 2 cents
MikeS
@Mike, I know OBC has done a 'getting started with the Prop' book, with weekend projects just like that. Can't find the link at the moment, but it's on the forum.
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
You can register here:
http://www.parallax.com/tabid/742/Default.aspx
MikeS
That Propeller sticker is for the rear bumper of your car. Show the world your Propeller geekyness.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
