2 Important tools for Interfacing/Debugging, and a new project to combine them — Parallax Forums
Jimmy W.Jimmy W. Posts: 112
edited 2009-03-10 01:12 in Propeller 1
Just wanted to share my experiences with other propheads, I got this about 3 weeks ago and I cant say enough about it, so I will let it speak for itself Logic - http://www.saleae.com/logic/ Also I just built the dip version of The Bus Pirate - http://hackaday.com/2008/11/19/how-to-the-bus-pirate-universal-serial-interface/ As much as I love them, The reason I bring this up is I am looking to combine Viewport with some code on other cogs to be able to combine the functionality of the 2 tools into a single prop, I also want to include some 12v> 3v3 v translators that are software selectable into the little rig, does anyone have other ideas about what could should be done? I was planning on serial, i2c, SPI, and 1 Wire, I need to learn alot more about CAN to be able to work with that but I know its something people want. I already have a decent bit of code for Autobaud detection( 30 seconds of looking for smallest signal)
So, any suggestions?
Jimmy
Post Edited (Jimmy W.) : 3/7/2009 10:11:20 PM GMT
  • HannoHanno Posts: 1,130
    edited 2009-03-08 01:10
    Good idea Jimmy!
    Sounds like you want an "IODreamkit". Have a look at what my dad built: mydancebot.com/viewport/dreamkit.php
    The Propeller is very flexible- and the Object Exchange has an object for pretty much any interface you could care about. Coupled with ViewPort for the interface you can do anything!
    Hanno
  • dMajodMajo Posts: 862
    edited 2009-03-09 20:38
    @Hanno,
    That logic analyser is also showing decoded data, adresses, start and stop bits...
    This·do not means the propeller is not capable of it. It means you should add a nice plug-in to your viewport to decrypt and show in plain text serial protocols (rs, spi, i2c ...)tongue.giftongue.giftongue.gif
    dMajo,
    I'm working on it- some support for serial protocols decoding is already hidden in ViewPort. I'll be in releasing a plugin soon. If you want to write your own plugin check this out: ViewPort Development Kit Tutorial
    Hanno
