None of the Stamps can directly use an MMC card or SD card. There are a variety of external accessories for the Stamps that do this very nicely. Parallax sells their Memory Stick Datalogger which uses USB "Thumb" drives. Hitt Consulting sells a datalogger that writes (and reads) to MMC cards (www.hittconsulting.com/sddatalogger.htm). Vinculum sells the VDrive which is similar to the Memory Stick Datalogger (since they may the chip that Parallax uses). There are others.
Parallax's Propeller processor can handle SD cards and MMC cards directly.
- Stephen
i mean ... can i use this microcontroller to write data on an external memory (MMC)..?
