UNM Mechanical Engineering students need help with RFID and motors
Hi All,
I am a mechanical engineering senior at UNM and my group and I are working on our capstone project. We're making an automatic pet feeder that will have an opening and closing lid to the food bowl so each pet can access their own bowl. We want to use RFID tags and readers to identify each pet as they approach their food bowl. We want the RFID reader to send a signal to a microcontroller and then have the microcontroller send a signal to a motor which will operate the food bowl lid and lift it.
We are really lost when it comes to the electronic part of things -- since we're mechanical. From the information I have received from Parallax, we will need a reader, a tag, a microcontroller, and a servo. What we need help with is understanding how to connect all of these parts and how to program them to interpret the signal from the RFID reader when the proper pet is at his bowl (and not another pet -- we don't want the bowl lid to open for another pet).
Any help would be fantastic! We are hoping to have this issue solved by the end of March.
Thank you!
Priscilla Kelly
Thank you!
Priscilla Kelly
Perhaps one of the challenges is that the pet must bring the tag within 3-4" of the RFID Reader. Hungry pets should be able to figure that out.
You could start by running the sample BS2 code on the Parallax web site for the RFID Reader. Look at "What's a Microcontroller?" for examples of servo control. Combine the two codes together with some tag reader logic and you'll be headed in the right direction.
The forum members aren't going to hand the project to you in a completed fashion. They're going to be really helpful answering focused questions, though. Your initial question is all-encompassing: how to connect all of these parts. Get specific and ask one question at a time. They'll also help you once they see that you're helping yourself since this is a student project. Don't look at this the electronics as "an issue" but something new to learn that will let you combine your mechanics with electronic control. This skill will make you desirable in the workforce, which is absolutely necessary in anybody's future.
You need to make the RFID reader work and you will need to recognize particular tag codes. You need to make a servo move in a particular way. You need to couple these two things.
Start with making the RFID reader work. There's plenty of information available including sample code. As with most Parallax products, go to the webstore page for the product. You'll see links to documentation, sample code, etc. I believe there's a Nuts and Volts Column on the RFID reader. Go to the main Parallax page and click on the Resources tab. You'll see a link to Nuts and Volts Columns. That'll get you to the index. There's a wealth of information in those columns. Browse them.
There's all kinds of information on servos and how they work. "What's a Microcontroller?" and "Robotics for the BoeBot" are two tutorials that will give you more information than you need on servos. Again, start with the Resources tab and choose Downloads, then Stamps in Class Downloads. You'll see an index to all of Parallax's Stamp tutorials with download links.
My team member and I have made a ton of progress since my last posting. We purchased all the supplies and downloaded Basic Stamp to run the RFID programs. We were able to read in the tag codes from the RFID tags and also have the computer program display which tag is at the reader. We have a programming issue (which I will discuss in a bit), but here's how our system is supposed to operate: there are two separate bowls for our automatic pet feeder and each one has it's own RFID reader and corresponding tag. Therefore, each of the two pets our product is made for will have his/her own tag for their own bowl. We have altered the code to power a motor to open the food bowl lid only for one pet's tag. If the other pet comes up to the bowl, the motor will turn on and the bowl will close -- because that pet is not allowed to eat at that bowl. We are only concentrating on making one bowl/closing lid system for our prototype. Our problem is that if the correct pet is eating from his/her bowl and walks away (out of the RFID reader range), we cannot get the motor to turn on to close (so nothing else gets into the bowl, like ants or pests).
I guess our problem mainly stems from understanding the code we found online to operate our system. We both are mechanical engineering students so Basic Stamp is a bit past our knowledge. I have a broad understanding of MATLAB and C++, if that helps.
Here's our code that we've altered so far. I highlighted the part where the computer program reads if there's a tag there. If you could provide any code-knowledge on how to get the motor to close (if it finds no tag during the second_check, after it has already been opened), that would be fantastic! Thanks so much. -Priscilla
Our code:
' File...... HB-25 Motor Test.bs2
' Purpose... Control HB-25 with RFID Reader
' Author.... Jeremy Chavez & Priscilla Kelly
' E-mail.... jchavez2@unm.edu,priskit@gmail.com
' Updated... 04-02-09
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description]
' This program was written in order to operate a feeding lid on a dog dish
'via RFID on the collar.
[noparse][[/noparse] I/O Definitions]
HB25 PIN 13 ' I/O Pin For HB-25
Enable PIN 14 ' low = reader on
RX PIN 15 ' serial from reader
[noparse][[/noparse] Variables]
index VAR Byte ' Counter For Ramping
[noparse][[/noparse] Initialization]
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 5 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor 1
Reset:
HIGH Enable ' turn of RFID reader
[noparse][[/noparse] Constants]
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
TMidi CON 12
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
TMidi CON 60
T38K4 CON 45
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
TMidi CON 108
T38K4 CON 84
#ENDSELECT
SevenBit CON $2000
Inverted CON $4000
Open CON $8000
Baud CON T2400
#SELECT $STAMP
#CASE BS2, BS2E
TmAdj CON $100 ' x 1.0 (time adjust)
FrAdj CON $100 ' x 1.0 (freq adjust)
#CASE BS2SX
TmAdj CON $280 ' x 2.5
FrAdj CON $066 ' x 0.4
#CASE BS2P
TmAdj CON $3C5 ' x 3.77
FrAdj CON $044 ' x 0.265
#CASE BS2PE
FrAdj CON $0AA ' x 0.665
#CASE BS2PX
TmAdj CON $607 ' x 6.03
FrAdj CON $2A ' x 0.166
#ENDSELECT
LastTag CON 3
#DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have
SPRAM?
#IF __No_SPRAM #THEN
buf VAR Byte(10) ' RFID bytes buffer
#ELSE
chkChar VAR Byte ' character to test
#ENDIF
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' tag byte index
char VAR Byte ' character from table
[noparse][[/noparse] EEPROM Data]
'Tag1 DATA "0415ED500F" ' valid tags - Here we commented out one of the tags to make it "invalid"
Tag2 DATA "0415ED4DC3"
Name0 DATA "BACK OFF FLEA BAG!", CR, 0
Name1 DATA "tag1(Jeremy)", CR, 0
Name2 DATA "tag2(Priscilla)", CR, 0
Name3 DATA "Tag 3 (Small Round)", CR, 0
[noparse][[/noparse] Program Code]
Main:
LOW Enable ' activate the reader
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
#ELSE
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
#ENDIF
HIGH Enable ' deactivate reader
DO WHILE (1<2)
Check_List:
FOR tagNum = 1 TO LastTag ' scan through known
tags
FOR idx = 0 TO 9 ' scan bytes in tag
READ (tagNum - 1 * 10 + idx), char ' get tag data from
table
IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table
#ELSE
GET idx, chkChar ' read char from SPRAM
IF (char <> chkChar) THEN Bad_Char ' compare to table
#ENDIF
NEXT
GOTO Tag_Found ' all bytes match!
Bad_Char: ' try next tag
NEXT
Bad_Tag:
tagNum = 0
GOSUB Show_Name ' print message
PAUSE 1
GOTO Main
Tag_Found: 'LET THE DOG EAT
PAUSE 20 ' Wait 20 mS Before Ramping
FOR index = 0 TO 200 ' Ramp Up To Full Speed
PULSOUT HB25, 750 + index ' Motor 1 Forward
PAUSE 1 ' 1 mS Delay For Motor 2 Pulse
PAUSE 20 ' 20 mS Smoothing Delay
NEXT
PAUSE 3000 ' Wait 3 Seconds
FOR index = 200 TO 0 ' Ramp Back Down
PULSOUT HB25, 750 + index ' Motor 1 Forward Slowing
NEXT
'----'Check to see if correct dog is STILL present! --Mr. Green, Here is where we need help. If the correct dog is not present, (i.e. he walked away and no dog is present), 'how can we get the motor to close? It closes if the incorrect dog comes up (goes to code titled "CloseMTR"). Thanks
Active:
#ELSE
#ENDIF
HIGH Enable
GOTO Second_Check
Second_Check:
tags
table
IF (char <> buf(idx) ) THEN CloseMTR ' Close the lid
#ELSE
IF (char <> chkChar ) THEN CloseMTR ' Close the Lid
#ENDIF
NEXT
GOTO hold
NEXT
hold:
PULSOUT HB25, 750 'Hold motor right where it is!!!
GOTO Active 'Go Recheck to see if the correct dog is present
CloseMTR: 'The dog is done eating, close it so food is not stolen!
FOR index = 0 TO 223 ' Ramp Up To Full Speed
PULSOUT HB25, 750 - index ' Motor Reverse Accel.
NEXT
FOR index = 223 TO 0 ' Ramp Back Down
PULSOUT HB25, 750 - index ' Motor Slowing (Reverse)
' PULSOUT HB25, 750 - index ' Motor 2 Reverse Slowing
NEXT
' STOP
tagNum = 0
PAUSE 1
GOTO Main
LOOP
' Use STOP To Prevent State Change
[noparse][[/noparse] Subroutines]
' Prints name associated with RFID tag
Show_Name:
DEBUG DEC tagNum, ": "
LOOKUP tagNum,
[noparse][[/noparse]Name0, Name1, Name2, Name3], idx ' point to first
character
DO
READ idx, char ' read character from
name
IF (char = 0) THEN EXIT ' if 0, we're done
DEBUG char ' otherwise print it
idx = idx + 1 ' point to next
character
LOOP
RETURN
Read the section of the Stamp Manual on the GOSUB and RETURN statements. Look, for example, at "Show_Name" and how it's used.
You want to do the same thing for your Read RFID routine, your Open the Bowl, and your Close the Bowl routines. For example:
This would go into the part of the program with the [noparse][[/noparse]Subroutines] header (for convenience only ... it's not necessary to have the header. It's for documentation purposes only). You'd replace that section with a GOSUB CloseMTR statement. You'd also do the same thing with
You'd replace this in the main program with GOSUB Tag_Found.
Similarly, you'd have
Here you'd call GOSUB Read_A_Tag and when the subroutine returns, tagNum would either have the value zero for a bad tag or the index of the tag in the table (from 1 to lastTag).
Now you can just insert another call to Read_A_Tag and, if tagNum is zero on return, you call CloseMTR to close the bowl.
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/Level/a/ProductID/83/Default.aspx?SortField=ProductName,ProductName
That way you would know if the dog had walked off or was still at the bowl.
Shawn Lowe
When all else fails.....procrastinate!
If you are interested in seeing a video of the end result, let us know. We would be happy to share what we've accomplished.
Thanks again,
Priscilla
I think everyone would love to see a video of it. Especially the inner workings, mechanical as well as the electrical portions of it.
There is a spot on the forums for completed projects, once you are at that point.
Good Luck on your project.
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn't exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
