The Mad Scientist's Chronograph Needs your help Measuring time
I was wondering just how fast my BB gun fired at some of my homemade armor for a competition at mech-warfare.com
6 hours later I built a contraption that uses 2 bump switches 1 foot apart.
Formula:
T2 - T1 = Total time it takes to go from one bump switch to another
(Distance in feet) / (Total Time) = fps
Example:
19.29975 - 19.28540· = ·0.01435 seconds OR 14ms
3 feet / 0.01435· = 209fps
Hardware.....Check!
Electronics...Check!
Software..... Che...Wait, what?!?
Do you know of a some code that can help me solve my problem?
···· -Devin
"I can only ask every question once."
Formula:
Example:
Hardware.....Check!
···· -Devin
http://forums.parallax.com/showthread.php?p=732526
If you are using PULSIN to measure the time on a BS2, then the result in in units of 2 microseconds. For example, 14.35 milliseconds is 14350 microseconds, but the result returned by PULSIN will be b2b=7175 (µs*2). Then if distance is 3 feet (or was it 1 foot?), the formula to convert to feet per second is
3 * 1000000 / (b2b * 2) = 1500000 / b2b
Which includes the factor of 1000000 for microseconds and the factor of 2 for the PULSIN units. For example, 1500000 / 7175 = 209 feet per second
The math has a variable in the denominator, and on the Stamp, a binary division loop is the best way to deal with this, as follows:
b2b VAR Word ' transit time in units of 2 microseconds Fx VAR Word ' calculation variable for division loop Nx VAR Word ' dividend for division loop J VAR Nib ' index for division loop DO PULSIN 0, 1, b2b ' b2b is pulse width in units of 2 µs IF b2b THEN ' skip calculation if no pulse Nx = 1500 '---------binary division loop----------- FOR J=15 TO 0 ' 16 bits Nx=Nx // b2b << 1 ' remainder*2 Fx.bit0(J)=Nx / b2b ' next bit NEXT '---------------------------------------- Fx = Fx**10000 ' renormalize to make a decimal fraction DEBUG CR,"Velocity = ", DEC Fx/10, ".", DEC1 Fx, "ft/s" ' e.g. 209.0 ft/s ENDIF LOOP ' try again ENDThe above works so long as the velocity is less than 1000 feet per second.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 3/6/2009 8:05:48 PM GMT
Ok how am·I supposed to use one PULSOUT command with two push-buttons? Do·I wire them to the same pin? I tapped one of the push-buttons and it have me a reading of about 200 ft/s, which was awesome but how did it figure that out with only one tap?
' {$STAMP BS2p} ' {$PBASIC 2.5} b2b VAR Word ' transit time in units of 2 microseconds Fx VAR Word ' calculation variable for division loop Nx VAR Word ' dividend for division loop J VAR Nib ' index for division loop DO DEBUG HOME DEBUG ? IN8 'on one side DEBUG ? IN9 'on the other side of a foot IF (IN8 = 0)THEN HIGH 11 'light LED ELSEIF (IN9 = 0) THEN HIGH 10 'light other LED ENDIF PULSIN 8, 1, b2b ' b2b is pulse width in units of 2 µs changed pin 0 to pin 8 IF b2b THEN ' skip calculation if no pulse Nx = 1500 '---------binary division loop----------- FOR J=15 TO 0 ' 16 bits Nx=Nx // b2b << 1 ' remainder*2 Fx.BIT0(J)=Nx / b2b ' next bit NEXT '---------------------------------------- Fx = Fx**10000 ' renormalize to make a decimal fraction DEBUG CR,"Velocity = ", DEC Fx/10, ".", DEC1 Fx, "ft/s" ' e.g. 209.0 ft/s ENDIF LOOPMy contraption at the moment is only 1' apart at the moment but·I can change it whenever·I want.
···· -Devin
PULSIN 8, 1, b2b ' <--- note that this command detects the duration of a 010 pulse
What exactly is a "bump switch" and how is that set up to detect the BB?
Tracy Allen
www.emesystems.com
