An easy question... but I can't figure it out
Hello, quick question: Are there any "less than or greater than" commands in stamp? I am trying to perform an instruction within a set of values so the·< and·> little guys would be very helpful... >_<
Is this what you meant? If not please explain what your trying to do so we can better help you.
The math operators are all explained in one section near the beginning, and also there is a long section on the IF command and its variants, and the SELECT:CASE command, and the LOOKDOWN command.
examples:
IF x<500 AND x>=200 THEN GOTO midrange SELECT x CASE >=500 GOTO highrange CASE <200 GOTO lowrange CASE ELSE goto midrange ENDSELECT LOOKDOWN x,<[noparse][[/noparse]200,501,65535],y ' y is 0,1, or 2 depending on range of x
Tracy Allen
www.emesystems.com
