Using a Proto USB Board
I have a Propeller Proto USB board and am·using some pin headers and jumping over to a bread board.·
Have been following one of the Propeller Education Labs, I/O and Timing Basics. Fun stuff, thanks for leading me along.
Had a volt meter hooked across Vss and Vdd and it read the 3.0 volts, normal right... Then I pulled the battery plug out.· The volt meter showed 1.5 volts.
What gives, the battery is disconnected....
Pulled the USB cable from the PC.· Voltage goes to zero.
So, here is the question, Does the board protect my PC, or is it possible that I could make a bone head move and push lots of volts into the USB cable?
I kind of also think that USB power line is 5V but what do I know.
Its quite likely that the voltage is coming from the TX line on the FTDI USB chip. That device sources its power from the USB and not the regulators on board.
What you are seeing is not at all unusual and nothing to worry about.
Perfectly normal.
Quite unlikely unless you blow up the FTDI chip. They are pretty well protected.
You know enough to be correct. The USB power line is about 5V. I have a board here I use for testing that I've jumpered the +5V from the USB socket to the 5V bus on-board so it's entirely USB powered. This is not recommended practice, but it sure works.
Cardinal Fang! Fetch the comfy chair.
A PC's USB connection is supposed to protect the PC from static and some applied voltage from out on the USB bus. There at least is protective circuitry in the USB interface in the PC. Whether it can "stand up" to the external voltage or not depends on the specific parts used and their specification.
