Trying to find wire connector for Parallax 1 wire Serial LCD — Parallax Forums
eagletalontimeagletalontim Posts: 1,399
edited 2009-03-04 00:39 in General Discussion
I have a product I hope to sell soon and I am using Parallax's 1 wire serial 2X16 display. It has 3 metal pins for the terminals and I have found that servo wires for R/C servos work but I am hoping to find a shorter version of this wire/connector so I can simply run the wires to my PCB.....preferably 3 inches. If anyone knows where I might find these, please let me know.
  • eagletalontimeagletalontim Posts: 1,399
    ok, and maybe one other part I will need as well..... Since I can only work with inexpensive parts, I have found a box enclosure with an area for the screen and enough room for my PCB. The only problem is the display mounting holes on the LCD are about 1/8 inch off. Does anyone know where I can find some kind of offset mounting bracket for the display? I have no idea what it would be called so I can't seem to find anything that will work in Google [noparse]:([/noparse]
